QUOTE(ClayPerrine @ Oct 3 2019, 06:13 AM)
QUOTE(jim_hoyland @ Oct 2 2019, 08:33 AM)
Question: I had the same thing happen when I first got my ‘75 L-Jet 914
I was told at the shop that it was from pumping the accelerator pedal when starting ?
Any thoughts on this ?
The L-Jet should start with no "pumping" of the accelerator at all. Just turn the key and go. If the engine backfires with the throttle closed, it won't warp the AFM flap. The throttle plate prevents it. If you have it open, that is when it can damage the AFM.
Thanks for the replies Clay,so would I be safe to assume as mine has the throttle plate that it may not be bent but sticking up for another reason ?
I haven't tried cleaning it with throttle body cleaner and have had success with this method in the past,worth a try I guess.
