QUOTE(brcacti @ Oct 3 2019, 03:18 PM)
Am not on a hill, so push start won't work where I'm at, I thought I read in the manual that you can't do that to these cars?, could be wrong.
even just a flat surface road, it is easy to push the car with just 1 person. I used to do it also on reverse. For safety, make sure you have a clear path because tendency of pushing the gas pedal and you will get a high rpm. if u feel the engine run already, quickly push down the clutch and play with the gas pedal so the engine will not die.
if not just jump start it with other car.
also you can buy one of this battery tender to keep ur battery fully charged when car will not be driven for days.
