QUOTE(rbzymek @ Oct 4 2019, 05:04 PM)
QUOTE(rbzymek @ Oct 4 2019, 02:52 PM)
Let me know if you would like to sell a a temp gauge that has nunbers on the dial. Trying to protect a new 2056 long block with better instrumentation. Thanks!
Ray
This would connect to the oil temp sensor on the taco plate.
For what it's worth numbers don't add any protection. It's all a mater of visual calibration.
Let me suggest a free experiment.
Hook up gauge on the bench. Insert temperature sensor into a cup of boiling water. Allow reading to stabilize. You know know exactly where 212 degrees is.
If you wish to calibrate higher temps, you will need a separate candy thermometer that will read up to about 400F. repeat experiment with oil (vegetable oil smoke point is ~ 400F) instead of water. You can now easily calibrate visually to 250F or beyond where you'd ever want the oil temp.
Not against the numbers but who's to say those were correctly calibrated?
@914sixer Sorry Mark, not trying to cock block a sale. Somehow we both posted at same time. I've thought about buying that very gauge a time or two! Ray, if you're set on numbers - you'll have a hard time finding one for a 914 that fits the 914 console other than what Mark has done which is to make a custom one that fits properly.
