QUOTE(brcacti @ Oct 5 2019, 10:08 AM)
Hello, my 914 would not start, it would fire a few then ONLY turn over without starting. It was acting like it was out of gas but the gauge said more than 1/8 and less than 1/4 tank. My question is even though it was showing some gas could it really have been out of gas? Has anyone else experienced no gas while still showing some registered?
Can happen. Stuck float is one possibility. Tank outlet screen clogged with debris on bottom of the screen could be another.
However, these tanks are easy to look into. . . just don't use a match.
Seriously, though, if you remove the fuel cap you can see right in there with a flashlight. That will tell you if there is fuel in there. Or, slosh it - you'll hear it.
More likely scenario is a failing fuel pump or clogged fuel filter.
