make sure that you set the dwell first as it directly affects the timing, and check the mechanical advance for proper operation
QUOTE(shane @ Oct 5 2019, 04:36 PM)
Been a few years since I used a timing light, but can’t I just run my 1.8 non vacuum advanced distributor carbureted engine up to 3000 rpm and turn my distributor with my timing light blinking until I have 27°BTDC (or higher?)in the notch? I tried understanding my timing light instructions and got lost. Or what is the most accurate way? Thanks in (advance)
