QUOTE(brcacti @ Oct 9 2019, 08:14 PM)
Hello and thanks for your help, Yes each morning I leave at 4:30 when dark I turn the black knob counter clockwise and it opens up, doing it manually. Wondering what I should try next if not the relay problem
Wiring diagram and Digital Multi-meter are your friend. Electrical work doesn't lend itself to guessing.
The guide posted above is nice! However, as a former electronics tech, I'd say you're better off in the long run learning to use a DMM and to read a wiring diagram than blindly following directions.
The 1st time is hardest, and with the nice guide above it really would be a great tutorial. From the wiring diagram you should be able to see where the directions are coming from w.r.t troubleshooting the circuit.
