Different labels but I suspect the same mfg. SOT: because this is on a conversion car.
This was the first to go. It was installed on the starter solenoid circuit to reduce the load on the switch. I'm guessing the amp load was < 3A. Relay is rated for 10x that amount. Look how misaligned the contact is. It was only contacting on the edge. Both relays #1-would make contact when activated but would not pass enough voltage to work. #2- had misaligned contacts that appear be made of copper and have rounded edges.
This one controlled the right side fan and was sealed so I cut it open.
Same issue here with the misaligned contacts. Load on this one is <13A. Both of these relays would pass the bench test when ohming out but neither would pass enough voltage to operate the fan or starter solenoid. I tried t capture the contact point between a set of contacts. It is a very small spec on the bottom side of the middle contact. I'll ask around before buying anymore relays.
