In the past few weeks i've missed some good deals, and scored others. (the subaru motor got away.
On the menu,
new rocker assemblies with 911 adjusters
shift bushings front to back
valves and timing, (and check to make sure i have that little spring under the dist.
adjust rear calipers
change brake fluid
oil and filters
spark plugs (oust the platinums just to see)
check gear oil
pressure wash the rear engine and transmission area to prep for some rust repair in the trunk.
If anyone is up for a little bbq
Kelly and I will be there all weekend, and will be having a happy 4th. Maybe even a little sunday cruising back in the hills.
peace,
brer
