Dr. Roger
Jun 30 2005, 05:16 PM
what would you use as a minimum diameter lines going up front.
I'm thinking I will use steel or copper. 30 bucks.
Anyone know of the cheapest connection for Gates green stripe? Cost?
Rog
914GT
Jun 30 2005, 05:30 PM
3/4" pipe works fine. I wouldn't go smaller. Bigger is ok but not necessary.
Dr. Roger
Jun 30 2005, 05:34 PM
can you think of any reason for not using steel elect. conduit? I will be using 25% coolant....
914GT
Jun 30 2005, 06:00 PM
QUOTE (rogergrubb @ Jun 30 2005, 04:34 PM) |
can you think of any reason for not using steel elect. conduit? I will be using 25% coolant.... |
Conduit and copper pipe easier to work with, less crush resistance. But if you do a good job tucking the pipe into the indentations under the floorpan it will be protected quite well. I've noticed that galvanized fittings get a 'furry' looking corrosion in them which I have not seen with plain steel pipe. Copper or aluminum preferred over galvanized. If you want no worry of crushed lines go with black steel pipe. A pain in the butt to bend, but I jack the car up under my lines.
