bkrantz
Aug 3 2020, 07:40 PM
I also took apart the intake plenum and throttle body.
bkrantz
Inside the plenum: oily sludge!
djway
Aug 3 2020, 10:57 PM
Regarding all the Red, what can I say it was the 80's. Girls had big tall hair and us guys painted everything body color.
bkrantz
Aug 4 2020, 07:59 PM
Still sorting through boxes from the disassembly last fall. This is all the "extra" electrical stuff: an awesome audio system with cassette deck, amp, and 4 speakers; an alarm system that was wired in to about 10 places, at least 2 hidden start disable switches, an ignition start bypass with solenoid, and about 10 miles of wire.
Anybody want some?
bkrantz
Aug 4 2020, 08:03 PM
Here's the fuel pump, with some red--but not the real RED. The PO did relocate the pump--to inside the right rear fender! It runs with power (or at least makes noise).
bkrantz
Aug 4 2020, 08:06 PM
Another project: the relay board. Ugly.
bkrantz
Aug 4 2020, 08:08 PM
The underside is even uglier, and the dielectric material is loose and spontaneously falling out.
bkrantz
Aug 4 2020, 08:10 PM
A little persuasion, and the stuff comes off. I need to clean this up, check all the leads, and refill with dielectric epxoy.
bkrantz
Aug 4 2020, 08:13 PM
Next up: the brain box. Another great OP idea, painting it black.
bkrantz
Aug 4 2020, 08:14 PM
At least the inside looks clean.
bkrantz
Aug 5 2020, 08:03 PM
I made a first pass at cleaning the brain today, with some acetone.
bkrantz
Aug 5 2020, 08:04 PM
That took off the black, but left the red (overspray, not the intentional Red).
bkrantz
Aug 6 2020, 07:50 PM
A follow-up with progress on the brain box, after some careful application of paint remover.
bkrantz
Aug 6 2020, 07:52 PM
The metal finish is still ugly. Not sure what to try next.
bkrantz
Aug 6 2020, 07:55 PM
The relay board looks better. Soaking overnight in GoofOff dissolved most of the remaining tar. I have some leads on dielectric potting epoxy, to refill the board and re-insulate all the leads.
bkrantz
The top side also looks better.
bkrantz
Aug 6 2020, 07:58 PM
Meanwhile, I have continued working on the main harness. I have identified and labeled all the plugs, leads, and components, and searched for more damage to repair. Got as far as the rear firewall. Still optimistic.
bkrantz
Aug 6 2020, 08:09 PM
Posting this photo here so I can link it to the VIN database. The is the owners manual that came with my car (but obviously not the original).
bkrantz
Aug 6 2020, 08:10 PM
And the next page.
bkrantz
Aug 7 2020, 08:41 PM
Oh fudge! While sorting through more boxes of parts I found a section (actually 2 pieces) of engine sheet metal that I forgot. This is the front section.
bkrantz
Aug 7 2020, 08:43 PM
I wanted to get this to the powder coating shop to include with all the other parts, and so quickly worked to straighten out some bends and dents, and weld one spot. I got to the shop just after 2:30, but they go home at 2pm on Friday.
bkrantz
Aug 8 2020, 08:54 PM
Back at work on the wiring harness, and I completed my initial cleaning and survey. I think it generally looks good, with just local problems to fix. I have also identified all the connectors and have some sense of where everything goes.
bkrantz
Aug 8 2020, 08:57 PM
I could not resist starting to fix things. Since I plan to move the fuel pump to the front I want to re-route and extend the existing wires. I started by pulling them from the branch tube that goes to the right side of the engine and battery.
bkrantz
Aug 8 2020, 08:58 PM
I then used a length of welding wire to snake the pump wires through the snorkel and main tube.
bkrantz
Aug 8 2020, 09:00 PM
Here are the pump wires, now reaching into the passenger compartment and heading "upstream".
bkrantz
Aug 8 2020, 09:01 PM
I also worked on the tail light lenses. I was careless with the left one, and broke the lower corner of the reverse light end. Fortunately, I saved the chips.
bkrantz
Aug 8 2020, 09:03 PM
I found some industrial acrylic welding fluid, that glues by partially dissolving the plastic.
bkrantz
Aug 8 2020, 09:05 PM
I also found cracks around one of the stud bases. But easy to fix with small drops of weld fluid that wick into the cracks.
bkrantz
The corner looks rough from "below".
bkrantz
Aug 8 2020, 09:06 PM
But pretty good in normal orientation.
bkrantz
Aug 8 2020, 09:08 PM
When I checked the right lens, I was surprised to see one stud broken off. I don't know when and how this happened--really!
bkrantz
Aug 8 2020, 09:09 PM
But relatively easy to repair with the weld compound. Seems reasonably strong after 30 min.
bkrantz
Aug 8 2020, 09:11 PM
And I also checked the fog lamps. One looks pretty good, except for minor pitting on the lens. Just needs a new gasket.
bkrantz
Aug 8 2020, 09:13 PM
But the other lamp has major issues, with corrosion in the case and a bent mount.
bkrantz
Plus rust inside the reflector. This one needs a sub.
bkrantz
Aug 9 2020, 07:41 PM
I took a look at the pedal cluster today. Overall, it looks really good, no rust, and already has bronze bushings.
bkrantz
Aug 9 2020, 07:42 PM
But the throttle lever has some interesting PO brazing. I will look to replace this.
djway
Aug 9 2020, 10:55 PM
QUOTE(bkrantz @ Aug 8 2020, 08:09 PM)
Only tighten the absolute minimum required...
bbrock
Aug 10 2020, 07:49 AM
QUOTE(djway @ Aug 9 2020, 10:55 PM)
I've made that repair on a couple lenses and even more severe breakage. They have held up well, but I do try to be careful to go slow when tightening the retainers and not over tighten.
bkrantz
Aug 10 2020, 09:10 PM
Have you guys ever replaced the foam gasket around the edge of the tail light lens?
bbrock
Aug 10 2020, 10:31 PM
QUOTE(bkrantz @ Aug 10 2020, 09:10 PM)
Assume you are talking about the round gasket cord inside the lip of the lens. Yes and no. I tried to replace with the 914Rubber cord but I'm sorry to say it was not acceptable. I'm told the AA gaskets are a dead match for OE so that will be in my next order. You can see the problems with the 914Rubber gasket material here:
http://www.914world.com/bbs2/index.php?s=&...t&p=2801670There is also a foam gasket between the tail light bucket and chassis. I replaced that with the 914Rubber gaskets and they fit perfectly.
raynekat
Aug 11 2020, 12:33 AM
QUOTE(bkrantz @ Aug 10 2020, 08:10 PM)
Yes.....does that help?
914 Rubber makes a nice replacement.
bkrantz
Aug 12 2020, 08:17 PM
Thanks, Brent. You are much more helpful than Doug.
bkrantz
Aug 12 2020, 08:20 PM
Cleaning wires is getting tedious. I spent about 2 house today, and got done with one long lead and two short ones. Here is a shot showing the before (left) and after (right). The red spots are where the PO paint, from spraying the inside of the trunk, got between the original spiral tape wrapping of the wire bundle.
bkrantz
Aug 13 2020, 08:01 PM
I carried on today, and finished cleaning the wiring for the trunk. This still need some repair work, with new connectors and a few bits of local replacement wire (plus the leads for the license plate lights).
bkrantz
Aug 13 2020, 08:03 PM
The wires look pretty good now, and seem intact--just a bit stiff in a few place.
bbrock
Aug 13 2020, 10:07 PM
Looking good. Try hitting them with some 303 Protectant and they may soften up. Mine did. I also soaked wire with overspray in brake fluid to soften the paint so it cleaned off (being careful not to get the ends of he wire in the fluid). That also seemed to softened the insulation and the harness was still supple a year and a half later when I reinstalled it.
bkrantz
Aug 14 2020, 08:28 PM
QUOTE(bbrock @ Aug 13 2020, 10:07 PM)
Good to know--I will try some of both.
bkrantz
Aug 14 2020, 08:31 PM
I got into wire repair mode today. Here is the setup, with soldering iron, heat gun, and other stuff.
bkrantz
Aug 14 2020, 08:34 PM
First up: 2 leads to the ignition switch plug. One was split and connected to new PO leads. The other has a new lead spliced in.
