bkrantz
Aug 14 2020, 08:35 PM
Starting with the yellow wire, I carefully removed the crimp connectors.
bkrantz
Aug 14 2020, 08:36 PM
Then weave the wire cores together.
bkrantz
Aug 14 2020, 08:37 PM
Then solder.
bkrantz
Aug 14 2020, 08:39 PM
I did the same for the red lead (and I managed to remember the heat shrink tubing for both).
bkrantz
Aug 14 2020, 08:40 PM
Slide the tubing into place. This is marine grade with internal adhesive.
bkrantz
Aug 14 2020, 08:41 PM
Then hit it with the heat gun.
bkrantz
Aug 14 2020, 08:42 PM
I did the same repair on two leads to the light switch.
bkrantz
Aug 14 2020, 08:44 PM
Today was another milestone. I went to the powder coat shop to fetch the first batch of refinished components. I used Evolution Powdercoating in Durango--highly recommended.
bkrantz
Aug 14 2020, 08:46 PM
Checking out all the parts. I remember everything except the heat exchanger ductwork, which got high temp powder coat.
bkrantz
Aug 14 2020, 08:47 PM
Here's the engine sheet metal, air filter housing, and intake plenum.
bkrantz
Aug 14 2020, 08:49 PM
Of course, powder coat, like paint, reveals any flaws in the metal. The section where I welded cracks is not perfect, but will work.
bkrantz
Aug 14 2020, 08:50 PM
Here's the front suspension, with a slightly lumpy steering cover.
bkrantz
Aug 14 2020, 08:53 PM
And the rear suspension. The biggest miscommunication led to getting the inside of the rear wheel bearing cavity powder coated. I will need to remove this before installing the bearings. The shop did a great job of protecting other areas and all threaded holes.
bkrantz
Aug 15 2020, 08:13 PM
I got my supply of colored wire (4RCustomsWire) and metric connectors (Bel Metric).
bkrantz
Aug 15 2020, 08:14 PM
Also a first time to use my fancy crimp tool, with correct jaws fitted.
bkrantz
Aug 15 2020, 08:15 PM
Here's a test crimp, with a typical spade connector. Looks very correct.
bkrantz
Aug 15 2020, 08:18 PM
And here's a typical repair: replacing about 6 inches of mangled original wire with the new piece soldered onto the remaining lead, covered with heat shrink tubing, a new connector, and heat shrink on that, too.
bkrantz
Aug 15 2020, 08:19 PM
For another repair, I replaced a complete section of wire, from one connector to the next. The crimp tool handles double wire without a problem. (The new wire color match is not perfect, tan vs. brown).
bkrantz
Aug 15 2020, 08:20 PM
New ring terminals for the battery tie-in, crimped and soldered.
bkrantz
Aug 15 2020, 08:21 PM
Another repair for a mangled lead--I even matched the green wire with white stripe (sort of).
bkrantz
Aug 15 2020, 08:24 PM
Here are the extensions for the fuel pump wires, attached to the leads that I re-routed through the snorkel. The new wires will eventually run all the way to the relocated pump up front.
djway
Aug 16 2020, 01:20 AM
If you don't already to this for a single wire terminal I start with the large jaw and crimp then I move to the middle jaw and get a much better result.
Keep on Crimpin.
bkrantz
Aug 16 2020, 07:17 PM
More wire repair today. Here's a replacement for the power lead to the cig lighter.
bkrantz
Aug 16 2020, 07:18 PM
And after a bit of black marker, the match is better.
bkrantz
Aug 16 2020, 07:21 PM
This is a real nice example of PO handiwork, a wire spliced into a lead to the left door switch. Presumably, this was for the aftermarket alarm.
bkrantz
Aug 16 2020, 07:38 PM
Step 1: Replace the mangled section.
bkrantz
Aug 16 2020, 07:39 PM
Step 2: Insulate the splice, and crimp both leads into a new mini-connector.
bkrantz
Aug 16 2020, 07:41 PM
Step 3: Insulate the connector, and bundle all the leads in prep for wrapping the harness with new tape.
bkrantz
Aug 16 2020, 07:43 PM
Here's a real special example. Twinned leads from one of the head light fuses, all melted. A PO short?
bkrantz
Aug 16 2020, 07:44 PM
Replaced, with some black marker stripes added.
bkrantz
Aug 17 2020, 07:48 PM
After measuring a friend's 914 (thanks, Mike!) I decided to complete the rear portion of the harness (everything in the trunk).
Here's the wiring laid out to match dimensions marked on the table.
bkrantz
Aug 17 2020, 07:50 PM
The center needs the most work, where I have to rebuild the leads to the license plate lights.
bkrantz
Here are the new wires, with connectors and insulation.
bkrantz
Aug 17 2020, 07:51 PM
And then wrapped with harness tape (from 914 Rubber).
bkrantz
Aug 17 2020, 07:53 PM
Wrapping the harness take a Zen mind state, trying to keep the spiral constant. Practice from years of wrapping road bike handlebars helps. I am glad to have one part of the harness done!
Cairo94507
Aug 18 2020, 01:37 PM
That harness looks really nice.
ndfrigi
Aug 18 2020, 02:01 PM
QUOTE(bkrantz @ Aug 16 2020, 06:38 PM)
Hello,
I may follow your lead sir to fix mine soon which was cut into half by the center tunnel line. Or maybe use the Heat shrink butt connector.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
bkrantz
Aug 18 2020, 08:47 PM
Thanks, Cairo.
Those butt connectors should work, but for the heavy gauge leads (for higher amp current), soldering might be better.
Any EE types can tell us the truth.
bkrantz
Aug 18 2020, 08:49 PM
More wire work today. I got some additional materials: super adhesive stretchy rubber tape and paint-on rubber coating, both by 3M. I am using these to patch wires with small nicks or cuts in the insulation.
bkrantz
Aug 18 2020, 08:50 PM
This makes the repair a little bulky, but I think better than cutting and splicing.
bkrantz
Aug 18 2020, 08:51 PM
More repairs.
bkrantz
Aug 18 2020, 08:53 PM
A different kind of repair on the power lead to the left fog light. These are bare wire with some solder tinning, that get clamped in a screw connection.
bkrantz
After
bkrantz
Aug 18 2020, 08:54 PM
I also stopped by the body shop today, and saw some good progress.
bkrantz
Aug 18 2020, 08:55 PM
Priming is all done, and spending a day or two for the paint to cure.
bkrantz
Aug 18 2020, 08:56 PM
Then block sanding can start.
djway
Aug 18 2020, 09:25 PM
To aid in your Zen state of mind
Ohhhhhhhhmmmmmmmmmmmmmmmmm
Kansas 914
Aug 19 2020, 06:11 AM
76-914
Aug 19 2020, 07:26 AM
QUOTE(Kansas 914 @ Aug 19 2020, 05:11 AM)
Good one. I'll show that to my wife. She's a Buddhist.
bkrantz
Aug 19 2020, 08:33 PM
Thanks, guys. I can feel the boost in karma.
