bkrantz
Dec 16 2020, 08:35 PM
Then the tail light branch.
ndfrigi
Dec 16 2020, 08:36 PM
Congratulations! not just installing it but the patience in getting lots of pictures of every step! Thanks for sharing! Now time for engine installation!
bkrantz
All of the left branch through.
bkrantz
Dec 16 2020, 08:38 PM
And the right branch with the battery leads through.
But here's the problem: the snorkel is too stiff to bend and get its upper end through the hole in the shelf!
So I pushed the lower end of the snorkel back into the tunnel to shorten the part sticking out.
bkrantz
Dec 16 2020, 08:42 PM
Now I could feed the upper end of the snorkel through the shelf, and then reseat the grommet on the lower end into the firewall hole.
More red spots?
bkrantz
Dec 16 2020, 08:44 PM
Turns out I found lots of sharp edges with my fingers and knuckles. The risks we have to take?
bkrantz
Dec 16 2020, 08:46 PM
That's success for the rear harness through the tunnel and firewall! The coiled wires here are for the interior light and the parking brake. These need some grommets where they exit the tunnel.
djway
Dec 16 2020, 11:26 PM
QUOTE(bkrantz @ Dec 16 2020, 06:44 PM)
Vampire chum...
raynekat
Dec 17 2020, 03:09 AM
Nice job there Bob. That was a painful, cursing task from what I remember. I wasn't in a good enough mood to take all the pics you did. Well done. Have a beer on me.
Kansas 914
Dec 17 2020, 07:43 AM
Stellar work Bob!
BillC
Dec 17 2020, 09:10 AM
Extremely nice. Well done!
Thanks for all the pics.
bkrantz
Dec 17 2020, 08:00 PM
QUOTE(raynekat @ Dec 17 2020, 02:09 AM)
Thanks, Doug. I agree--good mood is important for some tasks.
bkrantz
Dec 17 2020, 08:01 PM
QUOTE(Kansas 914 @ Dec 17 2020, 06:43 AM)
Stellar work Bob!
Thanks, Mike. I need to invent a reason to see something on one of your cars (assuming your garage is still accessible).
bkrantz
QUOTE(djway @ Dec 16 2020, 10:26 PM)
Vampire chum...
That explains the guy in the cape.
bkrantz
Dec 17 2020, 08:03 PM
Just a couple of trivial things today, including the grommet for the interior light wires.
bkrantz
Dec 17 2020, 08:04 PM
And cleaning the grounding stud under the dash.
Kansas 914
Dec 18 2020, 08:03 AM
QUOTE(bkrantz @ Dec 17 2020, 07:01 PM)
You are welcome anytime - though the cars are put away for their Winter nap I can get them out quite easily.
bkrantz
Dec 18 2020, 07:55 PM
QUOTE(Kansas 914 @ Dec 18 2020, 07:03 AM)
Click to view attachmentThat looks like the "before" picture in an ad for garage extensions!
bkrantz
Dec 18 2020, 07:56 PM
Back to work today, on the front end of the wiring harness.
bkrantz
Dec 18 2020, 07:58 PM
All that has to go through the small hole (big hole is for ventilation duct).
bkrantz
Dec 18 2020, 08:09 PM
This is definitely the time for "biggest goes first", like the 4-pin plugs.
bkrantz
Dec 18 2020, 08:10 PM
Here we go.
bkrantz
Next, the far ends of the front light leads. The unwrapped wires are for the future washer pump.
bkrantz
Dec 18 2020, 08:12 PM
More leads started through the hole. Note the big flag connectors (upper left) are for one of the headlights, and do not have the large plastic connector plug around them (yet).
bkrantz
Dec 18 2020, 08:15 PM
Progress, from the inside.
bkrantz
Dec 18 2020, 08:16 PM
Everything is now at least started.
bkrantz
Dec 18 2020, 08:17 PM
Squeezed the fuel tank bulkhead grommet through.
bkrantz
Dec 18 2020, 08:18 PM
I attached the ground leads to the stud while still plenty of room.
bkrantz
Dec 18 2020, 08:19 PM
And then got the big grommet seated. It still shows some signs of gnawing by mice.
bkrantz
Dec 18 2020, 08:21 PM
Another personal milestone: this is the first time I have taken parts out of the hundreds of labeled bags.
bkrantz
Dec 18 2020, 08:22 PM
Fuse-relay panel in place.
bkrantz
Dec 18 2020, 08:23 PM
All the wires that will go in or under the dash.
bkrantz
Dec 18 2020, 08:25 PM
Now for the wires in the front.
bkrantz
Dec 18 2020, 08:26 PM
Starting the leads through the fuel tank bulkhead.
bkrantz
Dec 18 2020, 08:27 PM
Pretty full--all the leads started.
bkrantz
Dec 18 2020, 08:28 PM
From the tank side.
bkrantz
Dec 18 2020, 08:29 PM
Grommet seated (and more blood shed).
bkrantz
Dec 18 2020, 08:30 PM
Quick layout of the light leads.
bkrantz
And the leads for under the cowl and fuel tank.
bkrantz
Dec 19 2020, 07:52 PM
First step today: removing paint from more grounding studs, starting with the one by the engine relay board.
bkrantz
Dec 19 2020, 07:53 PM
Then the stud by the battery. Before...
bkrantz
Dec 19 2020, 07:54 PM
After.
bkrantz
Dec 19 2020, 07:55 PM
And the stud for the transaxle grounding strap.
bkrantz
Dec 19 2020, 07:57 PM
OK, ready to start on the harness routing in the engine compartment. But first I have to repair a tear in the harness cover, just above the snorkel.
bkrantz
Dec 19 2020, 07:58 PM
Time for some 3M rubber tape.
bkrantz
Dec 19 2020, 08:00 PM
Better.
bkrantz
Dec 19 2020, 08:03 PM
Right harness branch, leading to the battery.
bkrantz
Dec 19 2020, 08:07 PM
Left branch, first to the relay board and the blower fan.
bkrantz
Dec 19 2020, 08:08 PM
And then the lead to the trunk light.
bkrantz
Dec 19 2020, 08:09 PM
Leaving the leads to the tail lights.
