bkrantz
Feb 5 2021, 08:36 PM
With just a bit of time, I decided to mount the muffler shield. I modified this to bolt in, and had the shield powder-coated with high-temp material.
bkrantz
Feb 5 2021, 08:37 PM
Here are the receiving studs, on the underside of the trunk, on custom Z-brackets.
bkrantz
Feb 5 2021, 08:39 PM
A bit too much paint on the studs, so...
bkrantz
Feb 5 2021, 08:40 PM
I ran a die over the threads.
bkrantz
Feb 5 2021, 08:42 PM
Shield in place. I may redo the fasteners with hi-temp anti-seize.
john77
Feb 5 2021, 08:57 PM
Nice job on modifying the muffler shield. I was looking at mine last weekend wondering how I can strip the trunk floor beneath it - is it originally spot welded on?
raynekat
Feb 5 2021, 09:33 PM
That looks great Bob.
I coated my heat shield with the same ceramics that are put on mufflers.
Time will tell if it helps with heat into the rear trunk.
Mine is also easily removable with a couple of nuts.
There's mine lurking back there in some kind of silver ceramic color....
Your car is looking so good (incredible).
Will you ever drive it I wonder?
bkrantz
Feb 6 2021, 08:01 PM
QUOTE(john77 @ Feb 5 2021, 07:57 PM)
Originally, the shield was attached with C-shaped brackets, welded to the shield and floor. I wanted to be able to remove mine, so made it bolt-in.
bkrantz
Feb 6 2021, 08:03 PM
QUOTE(raynekat @ Feb 5 2021, 08:33 PM)
Thanks, Doug. I sure hope I can drive it (i.e. first get it running, and then get myself to take it on the road). I already have an almost garage queen.
bkrantz
Feb 6 2021, 08:05 PM
A bit out of order, but I installed the rear sway bar. Just enough room to sneak it past the muffler shield.
bkrantz
Feb 6 2021, 08:07 PM
I also temporarily mounted the left trailing arm, mostly to check on hardware (and decided to order new M14 lock nuts).
bkrantz
Feb 6 2021, 08:11 PM
And then got ready to assemble the rear shocks and springs. First I decided to drill holes in the spring perches so I can tie the springs if necessary.
I am still getting used to my new mega drill press. I am also trying to be more precise about drilling, and use my vise mounted to the press table.
bkrantz
Feb 6 2021, 08:13 PM
Spring perches with holes chamfered and smoothed.
bkrantz
Feb 6 2021, 08:14 PM
Now I am trying to get the hardware order sorted out.
bkrantz
Feb 6 2021, 08:16 PM
I moved the shock spring perch up to the second groove from the bottom, but that leaves some slack space below the spring. I might try the 3rd groove.
bkrantz
Feb 7 2021, 07:46 PM
A bit more work on the dash today. I decided to delete the seat belt warning light, and so need to block the small rectangular hole.
bkrantz
Some quick snips with the metal shears.
bkrantz
Feb 7 2021, 07:47 PM
Here's the filler piece glued to a backing plate.
bkrantz
Feb 7 2021, 07:48 PM
And both glued to the dash front plate. Glue means the mod should be easily undone.
bkrantz
Feb 7 2021, 07:50 PM
I also got a replacement rubber boot for the right headlight mechanism, and so worked on that.
bkrantz
Feb 7 2021, 07:51 PM
One more detail. I plan to use all LED replacement bulbs, and so replaced the flasher unit with one compatible with LEDs.
euro911
Feb 8 2021, 04:45 AM
Bob, are you installing individual LED turn signal bulbs/lamps (instead of Spoke's LED boards)?
Just wondering if one would need the 'LED compatible' flasher unit if using Spoke's boards (like I'll be doing - hopefully, some day)
bkrantz
Feb 8 2021, 07:59 PM
My plan right now is for individual LED "bulbs". That keeps things more easily reversed.
I don't know about what different flasher requirements (and other mods) might be.
bkrantz
Feb 8 2021, 08:01 PM
I have the seat belt light hole blocked (at least until I want to undo it).
bkrantz
Feb 8 2021, 08:04 PM
After a quick clean, prime and paint, all the dash pieces are ready. Note that I took the photo right after spraying the last coat. I used a satin finish, so the gloss should dry down.
bkrantz
Feb 8 2021, 08:08 PM
I dug out the frunk lid springs. Like everything else on this car, these had undercoating on top of overspray on top of original paint, and a bit of rust. I removed the crud, paint, and rust, and got them ready for paint.
bkrantz
Feb 8 2021, 08:12 PM
But to paint the spring winds, I needed to open the spring a bit. Here's my solution, with the springs stretched about 3/4 of an inch on a frame, and shot with self-etching primer.
bkrantz
Feb 8 2021, 08:13 PM
And then black.
bkrantz
Feb 8 2021, 08:16 PM
One more detail today: the gas cap. I stripped off the PO's beloved red paint, and pried out the crumbling original gasket.
bkrantz
Feb 8 2021, 08:17 PM
New gasket installed.
bkrantz
Feb 10 2021, 08:14 PM
More parts arrived, so I finished the right head light assembly.
bkrantz
Feb 10 2021, 08:15 PM
Ready for lamps and trim. I got some LED head lights to try.
bkrantz
Feb 10 2021, 08:19 PM
I also got parts and hardware for the rear suspension, except for the rubber bump stops. (See my other thread). So I decided to install one shock without the spring to see about dimensions and spacing for the bump stop. Since the Bilsteins are gas-charged, I used a floor jack to move the trailing arm up.
bkrantz
Feb 10 2021, 08:20 PM
I checked the clearance at the top of the shock, and set it at 2 inches.
bkrantz
Feb 10 2021, 08:21 PM
Here's where the trailing arm sits with the 2 inch spacing.
bkrantz
And then 3 inch spacing.
bkrantz
Feb 10 2021, 08:22 PM
Trailing arm position.
bkrantz
Feb 10 2021, 08:24 PM
Here's the hardware I needed to complete the rear suspension installation, including new M14 lock nuts for the pivot shaft.
bkrantz
Feb 10 2021, 08:25 PM
With everything laid out, I decided to install the springs and shocks. Once I get the bump stops I can R&R the shocks.
bkrantz
Feb 10 2021, 08:27 PM
With the rear suspension in place, I can finish up the brake system. Here are all the new and rebuilt components.
QUOTE(bkrantz @ Feb 6 2021, 09:16 PM)
I think you need to go a lot higher, like two or three from the top.
euro911
Feb 11 2021, 03:19 AM
bkrantz
Feb 11 2021, 08:15 PM
QUOTE(mepstein @ Feb 10 2021, 07:27 PM)
Thanks--you might be right. I will have to take the springs off to add the bump stops and can adjust the preliminary height again.
bkrantz
Feb 11 2021, 08:16 PM
QUOTE(euro911 @ Feb 11 2021, 02:19 AM)
Thanks, Mark. I think they got more beer breaks than me. And they have cooler hats.
bkrantz
Feb 11 2021, 08:18 PM
I got to play with the rear brakes today. Step 1, clean residue from the new disks.
bkrantz
Feb 11 2021, 08:19 PM
Then remove the powder coating from the mounting ears.
bkrantz
Feb 11 2021, 08:21 PM
Mounted the backing plate. More new, re-plated, and powder-coated parts--shiny stuff.
bkrantz
Feb 11 2021, 08:23 PM
The new disk (with old retaining screws--I forgot to order new ones).
bkrantz
Feb 11 2021, 08:24 PM
A rebuilt caliper from PMB.
bkrantz
Feb 11 2021, 08:25 PM
Plumbed with the last sections of hard line and flex line.
