bkrantz
Feb 16 2021, 08:31 PM
Meanwhile, with the 3 screws that I have, I installed the headlight and the retaining ring.
bkrantz
Feb 16 2021, 08:32 PM
And then the lid.
bkrantz
Feb 16 2021, 08:33 PM
After just a quick adjustment, the fit looks OK. More adjustment to come.
raynekat
Feb 16 2021, 09:54 PM
Nice gaps there man....
euro911
Feb 17 2021, 04:34 AM
QUOTE(raynekat @ Feb 16 2021, 07:54 PM)
... almost as nice as this gap ...
bkrantz
Feb 17 2021, 08:00 PM
bkrantz
Feb 17 2021, 08:05 PM
Checking the fit of the new headlight surround from 914 Rubber.
bkrantz
Feb 17 2021, 08:07 PM
A bit more fiddling with the fit, especially matching the lid height to fender edge.
bkrantz
Feb 17 2021, 08:09 PM
On a roll, so what about the right headlight lid, even if I am missing the right hardware to install the new light.
bkrantz
Another quick fit adjustment.
bkrantz
Feb 17 2021, 08:11 PM
Starting to look more like a 914.
bkrantz
Feb 17 2021, 08:13 PM
More parts arrived, including a front caliper hardware kit from an Ebay supplier.
bkrantz
Feb 17 2021, 08:15 PM
The pad spreader spring is one piece, instead of the original riveted two-piece, but it has the correct spread: about 51 mm.
bkrantz
Feb 17 2021, 08:16 PM
This should work!
bkrantz
Feb 17 2021, 08:17 PM
I also got the missing magic inner adjuster gears for the rear calipers.
bkrantz
Feb 17 2021, 08:18 PM
So now I should have all the rear caliper hardware.
bkrantz
Feb 17 2021, 08:19 PM
So that meant I could finish the rear brakes. Actual pad clearance adjustment will wait until I install the sub axles. Oh, and that brake bleeding thing.
bkrantz
Feb 17 2021, 08:21 PM
I also got high-temp anti-seize.
bkrantz
Feb 17 2021, 08:22 PM
First place to use this is on the mounting hardware for the muffler shield.
bkrantz
Feb 17 2021, 08:25 PM
Last job today was to finish polishing aluminum trim, with the front and rear window weatherstrip retaining strips. These were also sanded and painted black by the PO.
bkrantz
Feb 17 2021, 08:26 PM
Not perfect, and with a few local dings, but at least shiny now.
bkrantz
Feb 17 2021, 08:28 PM
And I tried giving the targa hoop rear trim a polish of the anodized surface. This is a used replacement piece, not a backed-out version.
bkrantz
Feb 17 2021, 08:32 PM
Last thing that arrived today is adhesive for vinyl (targa hoop and dash to start). Based on recommendations and concern for (1) good stick to vinyl and (2) heat resistance, I decided on DAP Landau contact adhesive. And I found aerosol cans to go along with the 1 gallon liquid can, for brush-on.
iankarr
Feb 17 2021, 10:12 PM
Very cool that you can get it in spray cans now. Amazon?
bkrantz
Feb 17 2021, 10:28 PM
djway
Feb 17 2021, 10:43 PM
From what I remember the blue label can is already thinned for a spray gun but it has been a while.
Car is so pretty now I wouldn't even be able to sit in it....
iankarr
Feb 17 2021, 11:04 PM
I’ve sprayed right out of that gallon can. But def wear a respirator...it’s nasty stuff that will get you dizzy in minutes
bkrantz
Feb 18 2021, 09:36 PM
Thanks, guys. I got the liquid for if/when I need to brush some on, most likely around edges. I would have been happy to buy just a pint, but could only find the gallon size.
djway
Feb 18 2021, 11:31 PM
I'm not sure how well the thinned stuff brushes on. I would test first.
I use one on the $10 HF spray guns to spray it on. Clean with gasoline.
Use it up because it disappears like magic.
Puebloswatcop
Feb 19 2021, 10:17 AM
Wow, took me almost three days to read through this post. Thanks for sharing all the hard work and detail you have put into this 914. I will be resuming my restorations as soon as I can go to Colorado and retrieve the two I have and bring them down to Texas. I am retired now, so have time to work on them each day, you are a true inspiration.
bkrantz
Feb 19 2021, 06:41 PM
QUOTE(djway @ Feb 18 2021, 10:31 PM)
Thanks for the info. I will try it and report back. For spraying I got the aerosol cans--we'll see how well they work, too.
raynekat
Feb 19 2021, 09:43 PM
You had already bought your glue or I would have recommended this stuff.
It was absolutely the best and most Home Depots or Lowes have it on the shelf.
Will be interested to see how the glue you purchased works.
You should be fine I would think.
bkrantz
Feb 20 2021, 09:38 PM
I actually have that stuff, but on the 3M web site they seem hesitant to recommend that for vinyl. Instead they recommend number 80.
bkrantz
Feb 20 2021, 09:44 PM
I finally got to see my seats and other interior pieces. Not perfect (and not original) but I am very satisfied.
bkrantz
Feb 20 2021, 09:45 PM
Door panels look good, too.
bbrock
Feb 21 2021, 07:12 PM
Those seats look fantastic! Seeing things like that makes me curse being afflicted with CW disease.
bkrantz
Feb 21 2021, 09:17 PM
Brent, once I broke through the Original True Restoration barrier, I felt liberated, and was able to enjoy decisions like the color change, shaving the front side markers, and messing with the interior. I still feel like I am holding true to the spirit of the original 914 but I am sure somebody will argue with that.
bbrock
Feb 21 2021, 09:44 PM
QUOTE(bkrantz @ Feb 21 2021, 08:17 PM)
I'd say you are holding true. I'm loving the choices you've made. I did shave the warts. Some things just can't be tolerated. I've also added some modern safety features as stealthily as possible but what good is a perfectly original 914 if it gets flattened by a truck with you in it? I'm also running carbs but there is a story behind that.
wonkipop
Feb 21 2021, 10:48 PM
QUOTE(bbrock @ Feb 21 2021, 09:44 PM)
once you tear one down you are freed.
100% doing the right thing.
preservation is a bit of a burden.
like having the warts on it
the cars are for driving for the enjoyment.
its nerve wracking driving mine around in the "family truck" traffic down here.
esp. brakes. can not class those as enjoyable if am honest.
might have been top shelf in 1974, but way short now.
having gotten it going again i wish i had the $ to build myself another one,
completely gone over and sleeper-ed for the 21st century. like you are doing.
raynekat
Feb 22 2021, 05:34 PM
QUOTE(bkrantz @ Feb 20 2021, 07:38 PM)
Had no problem using it on the sail panel trim and dashboard face.
Your mileage may vary....
Oh and about that "originality" stuff.
At times I'm a stickler....other times not.
Do your own thang as they say.
Puebloswatcop
Feb 22 2021, 07:18 PM
I think your colors for the seats and cards is bold and they look fantastic, Great choice
bkrantz
Mar 2 2021, 08:23 PM
Finally home and ready to play in my garage again. Since I brought the recovered seats and interior parts home, I could not resist seeing how these look in the car.
bkrantz
Mar 2 2021, 08:24 PM
I also (literally) poked around on the center console panels. This is the right side interior.
bkrantz
Mar 2 2021, 08:25 PM
Months ago, I made paper templates to show all the holes for mounting hardware.
bkrantz
Mar 2 2021, 08:26 PM
I was able to find all the holes easily.
bkrantz
Mar 2 2021, 08:27 PM
I did the left side and other pieces, and will get on to assembly next.
Puebloswatcop
Mar 3 2021, 05:24 PM
QUOTE(bkrantz @ Mar 2 2021, 08:23 PM)
Those look great in the car. Once the carpet is in it will really pop
bkrantz
Mar 3 2021, 08:10 PM
I finished the center console assembly, first with all the metal brackets.
bkrantz
Mar 3 2021, 08:11 PM
And the end plate, with the original staple nails plus a bit of all-purpose glue.
bkrantz
Mar 3 2021, 08:13 PM
All done, with the bottom piece and the gauge panel. I am 90% satisfied--just the top seam along the right side that is not centered.
