bkrantz
Mar 7 2021, 07:43 PM
Cleaned up and almost ready to install.
bkrantz
Mar 8 2021, 08:32 PM
Next step on the dash: installing the front plate. I used 3M high strength double-sided auto adhesive tape.
bkrantz
Mar 8 2021, 08:33 PM
Stuck on, located by the holes for switches, etc.
bkrantz
Mar 8 2021, 08:34 PM
Dash is starting to look like a dash.
bkrantz
Mar 8 2021, 08:36 PM
I pulled out the original glove box. Its in pretty good shape, including the inner flocking, but has a bit of a bow along the front edge.
bkrantz
Mar 8 2021, 08:37 PM
I let the fiberboard soak and absorb some water, and then clamped the bowed edge--I hope it dries straight.
djway
Mar 8 2021, 10:05 PM
QUOTE(bkrantz @ Mar 8 2021, 06:37 PM)
I did one by holding it over a steaming pot of soup
gereed75
Mar 8 2021, 10:08 PM
I have thought of the thinned penetrating epoxies as a means of repairing fiberboard. They are designed to repair dry rotted wood by soaking in and then setting.
Seems would work on fiber board also. Get Rot is a brand name Among others
https://www.amazon.com/Boat-Git-Rot-Penetra...998&sr=8-30Have planned to use it to repair/re-enforce my back pad when I get around to it. Anyone have any experience with it?
bkrantz
Mar 9 2021, 08:54 PM
QUOTE(djway @ Mar 8 2021, 09:05 PM)
Come on, you have to be more specific--what kind of soup?
djway
Mar 9 2021, 10:37 PM
QUOTE(bkrantz @ Mar 9 2021, 06:54 PM)
Large pot homemade garden vegetable.
bbrock
Mar 9 2021, 10:59 PM
QUOTE(gereed75 @ Mar 8 2021, 09:08 PM)
I've used old fashioned wood glue to reinforce and repair the fiber board. For areas that are intact but floppy, I spritzed down the area to dampen with water and then painted over with wood glue to sort of dissolve int the dampness and soak into the fibers. To repair areas where chunks of fiber have come off but I still have them, I used the same technique but reinforced the repair with torn strips of brown paper applied like paper mache on both sides of the board. I then laid wax paper over the repair and clamped to hold the shape until dry. Worked great.
I also straightened my glove box using the same process a bkrantz. Also works great but I guess I missed out on the soup going that route.
gereed75
Mar 10 2021, 07:48 AM
[/quote] I’ve used old fashioned wood glue to reinforce and repair the fiber board. For areas that are intact but floppy, I spritzed down the area to dampen with water and then painted over with wood glue to sort of dissolve int the dampness and soak into the fibers. To repair areas where chunks of fiber have come off but I still have them, I used the same technique but reinforced the repair with torn strips of brown paper applied like paper mache on both sides of the board. I then laid wax paper over the repair and clamped to hold the shape until dry. Worked great.
[/quote]
That is a great idea. I think the trick is to get the adhesive of choice to soak into the fiberboard. Any similar paper, like a brown paper bag, would supply the reinforcing fibers
Basically a composite structure - fiber elements embedded in a bonding matrix. Not that it matters, but I wonder what the original adhesive used in fiberboard was?
I’ll File the wood glue one away in the memory bank for future use!
bkrantz
Mar 10 2021, 08:25 PM
Well, here's my glove box after drying in the clamps. Pretty straight. And since it only had a few small cracks, I will not try any glue or resin (for now).
bkrantz
Mar 10 2021, 08:27 PM
Before I started working on the dash, I installed the "new" reflector panel I got from KevinW for the right tail light. Thanks again, Kevin.
bkrantz
Mar 10 2021, 08:29 PM
After cleaning up the old glue and a bit of sanding to smooth out the mounting tabs, I glued it in place. Tail lights are now complete, except for LED bulbs.
bkrantz
Mar 10 2021, 08:30 PM
Now, on to the dash. Here are the pieces for the glove box lock, and the door handle.
bkrantz
Mar 10 2021, 08:31 PM
Lock installed
bkrantz
Door with handle, and mounting hardware. The "original" pivot screws are a mixed pair, so I dug into my hardware stash for some that match.
bkrantz
Mar 10 2021, 08:34 PM
Here's the door installed. Much easier with the dash on the work table.
bkrantz
Mar 10 2021, 08:35 PM
Viewed from the outside--looks even.
bkrantz
Also easier to install the actual box now.
bkrantz
Mar 10 2021, 08:37 PM
OK, time for the 914 Rubber replacement dash top. Again, I think I prefer to install this before mounting the dash in the car, or at least see how everything fits.
bkrantz
Mar 10 2021, 08:39 PM
First fitting attempt. The nylon mounting studs across the top of the dash fit well, along with the center stud on the face edge, but the stud mounts on the left and right side are a bit off. Time to enlarge the holes just a bit.
bkrantz
Mar 10 2021, 08:40 PM
I also realized that the ash tray bracket has to go on before the dash top.
bkrantz
Mar 10 2021, 08:41 PM
Fitting attempt number two. All the studs and holes now line up, and the front looks good.
bkrantz
Mar 10 2021, 08:42 PM
The windshield side is not bad, but a few spots are less than great.
bkrantz
Mar 10 2021, 08:46 PM
The match between the top and the new padded vinyl is good along the straight segments on right and left.
bkrantz
Mar 10 2021, 08:47 PM
But along the instrument cowl, the gap is a bit large and shows the edge of the dash top, which is a little rough.
bkrantz
Mar 10 2021, 08:48 PM
The biggest gap is on the sides of the cowl. I have a few ideas to fix this.
bkrantz
Mar 10 2021, 08:51 PM
Just for fun, and to check the fit, I installed the bottom dash knee bolster.
bkrantz
Mar 10 2021, 08:53 PM
I know the lower bolster has to come off to install the dash, but I like seeing how the whole thing will look.
bkrantz
Mar 10 2021, 08:54 PM
A few more things to deal with. The ash tray front is low, even with the bracket adjusted all the way up.
bkrantz
And the side gaps are a bit big.
raynekat
Mar 10 2021, 09:49 PM
QUOTE(bkrantz @ Mar 10 2021, 06:54 PM)
Compared to my gaps here.....yours look stellar.
Wouldn't sweat it too much.
euro911
Mar 11 2021, 03:10 AM
Looks great. After the fact, there's a re-flocking kit available for the glove box. I haven't done it (yet), but I've seen the results from some other members' applications and they turned out nice.
bkrantz
Mar 11 2021, 08:28 PM
QUOTE(raynekat @ Mar 10 2021, 08:49 PM)
Doug, I am way beyond being able to ignore things. (Help!)
bkrantz
Mar 11 2021, 08:30 PM
Big day today--installing the dash. I got the top studs into their holes, and then bolted the underside bracket.
bkrantz
Mar 11 2021, 08:31 PM
Then the top studs, accessed from the frunk side.
bkrantz
Then the side screws.
bkrantz
Mar 11 2021, 08:32 PM
And done! (I hope)
bkrantz
Mar 11 2021, 08:33 PM
From the front. I still need to deal with the gap around the instrument cowl.
bkrantz
Mar 11 2021, 08:34 PM
One more! I am excited since I have been waiting to get on with installing the blower, all the switches and gauges, and then testing the electrical system.
ElCee
Mar 12 2021, 02:20 AM
You better paint these two spots black.
NS914
Mar 12 2021, 09:03 AM
QUOTE(bkrantz @ Mar 11 2021, 10:33 PM)
Bob, your work and attention to detail is amazing...you like a number of other Teeners in our World are amazing! Thanks for posting such great images as well....you have me looking to remove my Muffler Shield and now and cleaning everything up underneath for sure.
I will be sitting down over the weekend and likely longer to go back and read your whole thread!
Much thanks, Grant
bkrantz
Mar 12 2021, 08:23 PM
Thanks for the tip, ElCee.
And thanks, Grant. Glad to share. Most days taking photos as I work keeps me steady.
bkrantz
Mar 12 2021, 08:26 PM
OK, add another error to my record. As I started to feed all the wiring across the inside of the dash, and install the pull switches left of the steering wheel, I found this. Can you figure out what I did wrong?
bkrantz
Mar 12 2021, 08:29 PM
After I mounted the front plate to the dash frame, I cut out all the holes in the dash face, without thinking. On my car, switches fill the 3 holes left of the steering wheel, and the cigarette lighter goes in the big hole on the right. But now I have 2 extra holes!
bkrantz
Mar 12 2021, 08:34 PM
While I think about what to do with the dash, I got going on the targa hoop vinyl and trim. A couple of weeks ago, I polished some aluminum trim, including the pieces that mount along the window sides of the sails. But I left the metal unprotected. Rather than clear coat, I decided to try a metal polish.
bkrantz
We will see how this stuff holds up to time and weather.
bkrantz
Mar 12 2021, 08:35 PM
On to installing the vinyl. I started with the top piece, and masked off the surrounding area.
