bkrantz
Mar 24 2021, 07:18 PM
I also found original switches, for rear window defroster and rear fog light.
bkrantz
Mar 24 2021, 07:20 PM
Once I install the cigarette lighter, I will have all the dash holes filled. And I have some plans for the new switches.
bkrantz
Mar 24 2021, 07:28 PM
I also got the missing targa trim piece from 914 Rubber, so I have left and right.
bkrantz
Mar 24 2021, 07:29 PM
Left side installed, with flat head screws in the rear holes.
bkrantz
Mar 24 2021, 07:30 PM
And right side.
bkrantz
Mar 24 2021, 07:32 PM
Then time for the rear edge trim piece. I treated the steel retaining clips with T-9 to prevent (more) rust.
bkrantz
Easy to tap into place.
bkrantz
Mar 24 2021, 07:43 PM
Then the fun started with the rear sail trim. I recycled the spacer for the upper screw. The screw hole in the new factory piece did not line up with the existing hole in the sail edge, so that required a new hole.
bkrantz
Mar 24 2021, 07:45 PM
Here's the trailing edge retaining clip, slid into the trim. But the fit is sloppy, so when I tried to get the nut started inside the fender, the protruding bolt vanished into the hole.
bkrantz
Mar 24 2021, 07:47 PM
My solution: a small roll of vinyl electrical tape, sticky side out, and wedged into the space to force the clip towards the bottom.
bkrantz
Mar 24 2021, 07:48 PM
With that I managed to get the nut started, and the trim installed. Looks good to me.
ndfrigi
Mar 24 2021, 09:49 PM
beautiful!
Puebloswatcop
Mar 25 2021, 08:23 AM
Bob, the car is coming along beautifully. Very nice workmanship and attention to detail as usual.
Kevin
Root_Werks
Mar 25 2021, 08:29 AM
Looking great!
Cairo94507
Mar 25 2021, 08:43 AM
That looks perfect!
I really think the sail panel vinyl adds so much to the look of our cars. On my 2nd Six, following some paint/rust repair, I left the sail panel vinyl off to see if I could get accustomed to that look. After about a week I put the vinyl back on. It's funny, because my default would always be to remove any vinyl roofing on cars as it just traps moisture and creates problems.
bkrantz
Mar 25 2021, 07:26 PM
Thanks, everyone.
Cairo, I agree about the sail vinyl. I have seen very few 914s that I think look good without it. One I did like (and made) was my 914 race car.
bkrantz
Mar 25 2021, 07:29 PM
I did the trim on the other side today, and got a few more photos of details.
Just like on the left side, the tab on the lower trim is elevated, so the trailing edge of the rear trim sits too high.
bkrantz
Mar 25 2021, 07:33 PM
To fix that I folded the tab down. The metal is soft aluminum, so pretty easy.
bkrantz
Mar 25 2021, 07:34 PM
That lets the rear trim sit flat on the bodywork.
bkrantz
Mar 25 2021, 07:36 PM
And just like on the left side, the existing screw hole did not line up with the new trim, but here was off by only a few mm.
bkrantz
Right side done.
bkrantz
Mar 25 2021, 07:39 PM
I was also changing tires on my 2017 911 today, and could not help comparing to the 914 tires. Note that my C2 has the smallest rear tires of all 911s for that year.
bkrantz
Mar 26 2021, 08:27 PM
One more sail trim detail--some glue for the forward end of the lower trim strip.
bkrantz
Mar 26 2021, 08:28 PM
While I was feeling sticky, I needed to reglue the end of the chrome trim strip on the lower dash bolster.
bkrantz
Mar 26 2021, 08:30 PM
And I got out the front and rear lid hinge brackets, to test the fit of new hardware.
bkrantz
Mar 26 2021, 08:34 PM
In the front, I installed the pivot plates. I will wait to install the lid bracket until I get the dash vents and hoses done.
bkrantz
Mar 26 2021, 08:38 PM
While I wait for some more orders to arrive I re-arranged my work space a bit, and got the stand out. Time to start some engine work. Soon.
bkrantz
Mar 27 2021, 07:11 PM
Successful gluing of targa bolster. Cracks are still visible but the padded vinyl is flat.
bkrantz
Mar 27 2021, 07:12 PM
And the chrome trim strip is now glued to the dash bolster.
bkrantz
Mar 27 2021, 07:13 PM
Time for the steering column. The PO had an auxiliary relay for the starter, so I suspect something in the ignition circuit is bad.
bkrantz
Mar 27 2021, 07:14 PM
Here's one problem: the original switch has cracked.
bkrantz
Mar 27 2021, 07:15 PM
New switch installed.
bkrantz
Mar 27 2021, 07:16 PM
I first put the column together on the bench.
bkrantz
Mar 27 2021, 07:17 PM
And tried to install this, including plugging in the connectors, but I had trouble getting the cables under the dash to cooperate.
bkrantz
Mar 27 2021, 07:21 PM
Instead, I pulled out the switch module, and installed the column housing with the ignition switch.
bkrantz
Mar 27 2021, 07:22 PM
And then the switch module, including the plugs (after arranging the cables under the dash a bit).
bkrantz
Mar 27 2021, 07:23 PM
Steering column in!
bkrantz
Mar 30 2021, 03:13 PM
I was digging through my big can of old nuts and bolts and stuff, and found these. From my previous episode of 914 madness almost 30 years ago.
djway
Mar 31 2021, 01:20 AM
Just like Shingles........
bkrantz
Mar 31 2021, 08:57 AM
QUOTE(djway @ Mar 31 2021, 01:20 AM)
Yikes! I hope not.
bkrantz
Apr 9 2021, 07:22 PM
Back home again, and back to work on the 914. A few things arrived while I was gone, including a cigarette lighter to replace the one I can't find.
bkrantz
Apr 9 2021, 07:24 PM
After installation, I have a full set of dash knobs.
bkrantz
Apr 9 2021, 07:27 PM
I also made a new set screw for the odometer reset knob. The original hole in the know was stripped out. I had a length of M4 stud with a screw groove in one end.
bkrantz
Apr 9 2021, 07:29 PM
Stud cut down to a minimal length.
bkrantz
Apr 9 2021, 07:30 PM
I drilled a larger hole in the knob and got out my metric taps.
bkrantz
Test fit on a spare cable.
bkrantz
Apr 9 2021, 07:32 PM
Next up: installing the gauges and connecting the last bits of wiring harness. Here is the gauge panel, with satin black powder coating.
bkrantz
Apr 9 2021, 07:33 PM
Here are the gauges I cleaned up months ago, and new ring gaskets.
bkrantz
Apr 9 2021, 07:35 PM
Another critical part of the 914 "look".
bkrantz
Apr 9 2021, 07:36 PM
Going through more stuff that arrived, a nice big box.
