bkrantz
Apr 21 2021, 08:44 PM
One thing I noticed is that the bearing shells do no sit evenly. On the rod half, the bearing protrudes just a bit.
bkrantz
Apr 21 2021, 08:45 PM
On the cap side, the bearing is just a little short.
bkrantz
Apr 22 2021, 07:52 PM
I finished checking the other rod bearing. All pretty consistent, with about 0.0018 inch bearing clearance.
bkrantz
Apr 22 2021, 07:53 PM
And about 0.016 inch side clearance.
bkrantz
Apr 23 2021, 07:04 PM
I got a small box of misc parts from AA. Just part of the endless list of stuff missing, gone missing, or otherwise necessary.
bkrantz
Apr 23 2021, 07:06 PM
I am probably excessive if not OCD, but I am happy to have the covers for the rear caliper outer adjusters.
bkrantz
Apr 23 2021, 07:07 PM
And happy to find the retainer for the cigarette lighter socket.
bkrantz
Apr 23 2021, 07:08 PM
I had used a hose clamp as a temporary fix, but this is better.
bkrantz
Apr 23 2021, 07:09 PM
Ready to light 'en up. (at least once I connect a battery)
bkrantz
Apr 23 2021, 07:11 PM
Now I have 2 retaining clamps on both air mixing boxes.
bkrantz
Apr 23 2021, 07:12 PM
That helped with the alignment of the defroster vent on the driver side.
bkrantz
Apr 23 2021, 07:14 PM
Back to restoring vinyl parts. So far I have tried both of these products, that both use the "restore" word.
bkrantz
Apr 23 2021, 07:16 PM
I have tried double applications, and overnight soaking, but can't see any real improvement in how brittle the old vinyl feels.
bkrantz
Apr 24 2021, 08:09 PM
Until I find a magic vinyl restoring potion, I will go ahead with what I have. I used the 3M stuff, but it left a high shine.
bkrantz
Apr 24 2021, 08:10 PM
To cut the shine, I used some 303 cleaner.
bkrantz
Still a bit shiny, but better.
iankarr
Apr 24 2021, 08:12 PM
I've heard that rubbing mineral oil into vinyl and leting it seep in can soften things up. Haven't tried it though...
bkrantz
Lower dash pad installed (for now). Looks more complete, and I like the contrast of the gray perf vinyl center.
bkrantz
Apr 24 2021, 08:14 PM
But the fit with the top pad is a bit sloppy on the ends.
bkrantz
Apr 24 2021, 08:15 PM
Time for more welting?
bkrantz
Apr 24 2021, 08:16 PM
Meanwhile, I got out the windshield washer plumbing.
bkrantz
Apr 24 2021, 08:17 PM
To install the squirters, the check valves have to come off.
bkrantz
Apr 24 2021, 08:19 PM
Then the squirters get inserted, and wiggled about to seat the rubber flange.
bkrantz
From below. I had to wiggle this one a bit more. Note this also has the check valve re-installed.
bkrantz
Apr 24 2021, 08:22 PM
I then ran the tubing, mostly following the wiring harness behind the air box. Hidden under the vent hose is the T-fitting that supplies the right side squirter.
bkrantz
Apr 24 2021, 08:24 PM
Plumbing under the reservoir.
bkrantz
Apr 24 2021, 08:25 PM
And with the reservoir removed.
bkrantz
Apr 24 2021, 08:26 PM
Now for the reservoir cap. Of course, this was originally set up to feed air pressure from the spare tire. Now I need it to vent to the atmosphere, but not allow fluid to slosh out.
bkrantz
Apr 24 2021, 08:28 PM
Nothing to lose, so I cut the valve in half.
bkrantz
Apr 24 2021, 08:29 PM
That reveals the internal valve--that I don't need.
bkrantz
Apr 24 2021, 08:34 PM
Here's the top. Both the barbed fitting and the open hole pass air.
bkrantz
Apr 24 2021, 08:37 PM
For now, I am not sure, but I think I will plug the hole and route a bit of tubing from the barbed fitting to prevent any fluid coming out, especially under braking.
bbrock
Apr 25 2021, 09:35 AM
What about installing one of these in that vent tubing?
https://www.amazon.com/1-4-Barbed-Check-Valve/dp/B01EMCPG2IYou could even use black rubber tubing and route it to look like stock if you are CW like me.
euro911
Apr 25 2021, 12:27 PM
That's what I was thinking, but I wonder how much vacuum pressure in the tank will allow it to open?
Maybe tying a loop in the vent tubing would work better - less resistance
DRPHIL914
Apr 25 2021, 01:19 PM
i am getting ready to do the exact same thing. nice detailed pics. i had not thought about cutting the valve body open. i ordered a 911 bottle supply so i could use the top opening for both vent and supply, and just cap off the bottom supply feed . but now i am rethinking that as the top cap for a 911 bottle used a slightly different size and threading
bkrantz
Apr 25 2021, 08:04 PM
Well, it probably had to happen, but I found a body issue that I forgot to address before getting the paint work done.
When I re-installed the right front fender, I made sure the seam between the fender and the cowl was open at the bottom so that water that gets under the seal can drain out. I meant to do the same thing on the left side but forgot. When I was thinking about installing the seal today, I remembered.
I inspected the bottom of the left seam and found some light rust. So that launched a recovery project.
bkrantz
Apr 25 2021, 08:05 PM
Right now, any water would be trapped, and will add to the visible rust.
bkrantz
Apr 25 2021, 08:07 PM
I removed the original seam sealer on the bottom side, and used some mini tools to scrape open the seam from the top.
bkrantz
Apr 25 2021, 08:08 PM
Eventually I got most of the seam open. Here's light showing from below.
bkrantz
Apr 25 2021, 08:10 PM
I got out the Ospho and a syringe.
bkrantz
Apr 25 2021, 08:12 PM
And then treated the seam from above and below a few times. I will think about other treatment and paint tomorrow.
Cairo94507
Apr 26 2021, 06:58 AM
Good catch. That should take care of it.
bkrantz
Apr 26 2021, 07:01 PM
QUOTE(Cairo94507 @ Apr 26 2021, 06:58 AM)
I hope so!
bkrantz
Apr 26 2021, 07:02 PM
I applied a healthy dose of primer, from above.
bkrantz
Apr 26 2021, 07:03 PM
And below.
bkrantz
Apr 26 2021, 07:04 PM
Then a first coat of yellow.
bkrantz
Apr 28 2021, 08:07 PM
Going back to last week, when I mounted the lower dash pad (knee pad) I was unhappy with the gaps at the tops of the side sections. I pulled the pad off, and then got out the same welting material I used to fill the gap I had around the instrument cowl part of the upper dash pad. I cut 2 sections and made some V-cuts to make bending around the corners easier.
bkrantz
Apr 28 2021, 08:08 PM
I mounted these with all-purpose adhesive and 3/8 inch staples.
bkrantz
Left side.
bkrantz
Apr 28 2021, 08:09 PM
Right side. I also glued a small break in the corner of the side panel.
