bkrantz
Jun 7 2021, 07:11 PM
Then I made my own jumper for the indicator lamps, following Spoke's design.
bkrantz
Jun 7 2021, 07:12 PM
Plus a 2 into 1 spade connector.
bkrantz
Jun 7 2021, 07:13 PM
The new ground jumper installed, connecting the indicator lamps to the ground terminal on the back of the tach.
bkrantz
Jun 7 2021, 07:15 PM
Success! Here are both indicators on with the emergency flashers on. They also work individually with the turn signals on. And I had to invert the left and right wires to reconcile the circuit change in the new flasher relay.
bkrantz
Jun 7 2021, 07:18 PM
I then checked out just about every other switch and component, and it looks like everything works--so far.
bkrantz
Jun 7 2021, 07:19 PM
One last detail today: I got out the new front fender gap seals.
bkrantz
Jun 7 2021, 07:20 PM
I installed them both, but left them uncut to see if they shrink a bit with time.
Cairo94507
Jun 8 2021, 07:10 AM
Looking beautiful.
Puebloswatcop
Jun 8 2021, 09:26 AM
Fantastic progress Bob. I just back from Colorado and sent my badly butchered wiring harness back here to Texas. Will be referring back to your wiring build to hopefully make a working harness.
Hope the head rebuild goes well. Cant wait to see the next phase.
Root_Werks
Jun 8 2021, 10:46 AM
Also still dealing with a butchered wiring harness. It's very frustrating when people don't understand what they are messing with.
Very nice! Love catching up on this thread.
930cabman
Jun 8 2021, 01:02 PM
QUOTE(bkrantz @ Jun 7 2021, 07:15 PM)
Our project has both turn signals and the 4 way flashers working, but not the indicator lights are not lighting. is there a separate feed for the indicator lights.
BTW: looks great
bkrantz
Jun 8 2021, 08:44 PM
QUOTE(930cabman @ Jun 8 2021, 01:02 PM)
BTW: looks great
Sounds like you have the same problem I had. The positive feeds to the left and right indicator lights in the tach (black/green and black/white wires, from the hazard switch) were working but the ground was not. I added the ground as per the design of Spoke and got the indicators to work.
bkrantz
Jun 8 2021, 08:46 PM
QUOTE(Root_Werks @ Jun 8 2021, 10:46 AM)
Thanks. The wire harness work was the most tedious part of the project so far. But now I am happy that I spent weeks with the harness laid out on a big table, and traced every wire and connection, and fixed everything that looked bad.
bkrantz
Jun 8 2021, 08:47 PM
Fuel pump runs (with the correct connection tab on the relay board grounded).
bkrantz
Jun 8 2021, 08:49 PM
Here's my idea for moving the interior light to the ashtray slot. Seems like a good place for a cabin light.
bkrantz
Jun 8 2021, 08:50 PM
I mocked up an insert that will hold the light fixture.
bkrantz
Jun 8 2021, 08:51 PM
This could work.
bkrantz
Jun 8 2021, 08:52 PM
Now to fab this, starting with some aluminum sheet metal.
bkrantz
Jun 8 2021, 08:55 PM
Here's the new bit of harness to extend the interior light leads. I already re-routed the existing wires from up between the seats to forward along the center tunnel.
bkrantz
Jun 8 2021, 08:56 PM
I ran the extension to follow the existing harness, behind the pedals and up under the dash.
bkrantz
Jun 8 2021, 08:57 PM
Ending up by the ashtray slot.
930cabman
Jun 9 2021, 04:54 AM
QUOTE(bkrantz @ Jun 8 2021, 08:44 PM)
BTW: looks great
Thank you Bob, could this be as simple as pulling the speedo and adding a ground wire?
bkrantz
Jun 9 2021, 06:41 PM
QUOTE(930cabman @ Jun 9 2021, 04:54 AM)
BTW: looks great
On mine, I pulled the tach, and removed the "ground" from the indicator lights (blue and white wire). I then added a ground jumper connecting both lights and the ground connection at the main bus on the tach.
bkrantz
Jun 9 2021, 06:43 PM
Here's the new interior light ash-tray fitting in aluminum. The second piece will attach the lamp holder to the underside of the original ash tray slide.
bkrantz
Jun 9 2021, 06:46 PM
More electrical testing. I could not get any voltage from contact in the cig lighter, and so pulled it out.
bkrantz
Jun 9 2021, 06:47 PM
I guess I had "temporarily" installed it without checking or cleaning it. Pretty nasty inside.
bkrantz
Jun 9 2021, 06:49 PM
And here it is all apart. Time to let the contact plate soak in Evaporust.
bkrantz
Jun 9 2021, 06:50 PM
One mark in the loss category, at least for now: my clock stopped working.
bkrantz
Jun 10 2021, 07:26 PM
Clock follow-up: when I connected the battery today, at first the clock did not run. Later it started ticking. So, I have a part-time clock?
bkrantz
Jun 10 2021, 07:28 PM
Back to the cig lighter, I pulled the lighter section apart, and cleaned the components.
bkrantz
Jun 10 2021, 07:29 PM
With all the rust and crud gone, I re-installed the lighter socket and tested the power--success!
bkrantz
Jun 10 2021, 07:30 PM
Now I have a functional cig lighter. I never expect to light any cigs, but it might be handy as a power outlet.
bkrantz
Jun 10 2021, 07:31 PM
And then back to my new interior light holder. Here is the internal bracket piece, screwed into the underside of the slide.
bkrantz
Jun 10 2021, 07:32 PM
One more temp fitting.
bkrantz
Jun 10 2021, 07:33 PM
To get the two pieces to stick in the right position temporarily, I got out my gallon of contact cement.
bkrantz
Jun 10 2021, 07:34 PM
Here are the two pieces stuck together.
bkrantz
Jun 10 2021, 07:35 PM
Final test fit. I think this will work, but it looks kinda plain.
bkrantz
Jun 10 2021, 07:37 PM
I found something that fits--what do you guys think? I would use a black logo over brushed aluminum.
bkrantz
Jun 10 2021, 07:40 PM
Moving along my shelf of parts, I checked the key in the door latches I removed way back in the beginning. I have 2 keys. The more warn key opens one door lock, but only the less warn key opens the other. Both keys work in the ignition.
bkrantz
Jun 10 2021, 07:42 PM
Next on the shelf was the box of seat belt parts. I had the original webbing replaced, and with a little color for the interior.
bkrantz
Jun 10 2021, 07:44 PM
First, I got the order of parts correct.
bkrantz
Jun 10 2021, 07:45 PM
I then made sure the internal spring in the reel was fully wound, and then inserted the belt end.
bkrantz
Jun 10 2021, 07:46 PM
This pin retains the belt end in the spool center.
bkrantz
Jun 10 2021, 07:47 PM
Here's the spool all set with the new belt.
bkrantz
Jun 10 2021, 07:49 PM
I also got new labels for the release buttons.
bkrantz
Jun 10 2021, 07:51 PM
Better. Note that I removed the plastic sheath and wires for the belt interlock warning system.
bkrantz
Jun 10 2021, 07:53 PM
Now to sort out the mounting hardware. I think I have the correct parts for the buckles.
bkrantz
Jun 10 2021, 07:54 PM
And for the shoulder yokes.
bkrantz
Jun 10 2021, 07:56 PM
But the correct pieces for the belt anchor are a mystery. Here are parts that came off the car, plus some others that I sourced.
bkrantz
Jun 10 2021, 08:02 PM
And to add to the confusion, I dug through my old parts for the box of belt hardware, including eye-bolts from my racing days. In the bag I found 3 more 914 mounting bolts.
