bkrantz
Jun 11 2021, 06:51 PM
Progress on my custom ash tray interior light holder. For this first attempt, I epoxied the two pieces together.
bkrantz
Jun 11 2021, 06:52 PM
I then went back to my custom LED fog light conversion, and how to complete the wiring.
bkrantz
Jun 11 2021, 06:53 PM
I fed the stock leads into the housing, as was original.
930cabman
Jun 11 2021, 06:54 PM
Bob, do you sleep?
bkrantz
Jun 11 2021, 06:55 PM
But there is not enough room in the cavity at the base of the housing for both the original leads and the new wiring.
bkrantz
Jun 11 2021, 06:57 PM
So I reverted to feeding the new leads out of the housing, with some additional cable housing.
bkrantz
Jun 11 2021, 06:59 PM
I need to find the right waterproof connector.
bkrantz
Jun 12 2021, 07:35 PM
QUOTE(930cabman @ Jun 11 2021, 06:54 PM)
Bob, do you sleep?
At least once a week.
bkrantz
Jun 12 2021, 07:39 PM
I think I finished my new ash tray light, but it took a couple of tries.
Both pieces expoxied together. Not as cool as welding, but maybe next time.
bkrantz
Jun 12 2021, 07:40 PM
After adding a groove for the retaining tab, the light fits--sort of.
bkrantz
Jun 12 2021, 07:41 PM
First problem: not enough clearance for the electrical tabs and connectors.
bkrantz
Jun 12 2021, 07:43 PM
Second problem: when I tried to bend the steel tabs, they broke off. So I soldered on some new tabs.
bkrantz
Jun 12 2021, 07:45 PM
Third problem: even with flag connectors, there was not enough clearance on the end inside.
bkrantz
Jun 12 2021, 07:47 PM
Fourth problem: when I tried to bend the soldered tabs, one broke off.
Final(?) solution: I replaced the tabs with short leads.
bkrantz
Jun 12 2021, 07:48 PM
Connections made up, joining the extension wires with the original leads that used to go up to the center of the back panel.
bkrantz
Jun 12 2021, 07:50 PM
And...it works. I need to check how the light functions in the dark, and I plan to replace the stock bulb with LED.
pilothyer
Jun 12 2021, 08:35 PM
QUOTE(bkrantz @ Jun 10 2021, 08:26 PM)
Clock follow-up: when I connected the battery today, at first the clock did not run. Later it started ticking. So, I have a part-time clock?
The Keinzel Clocks run for about 2 minutes, then as the spring unwinds it causes contact with the rewind circuit. This rewinds the mainspring for another 2 minutes of run time. I guess this was done to save battery life during times of unuse, but still keeping the clock's time correct. When they work correctly these clocks seem to last a long time.
bkrantz
Jun 12 2021, 09:18 PM
QUOTE(pilothyer @ Jun 12 2021, 08:35 PM)
Thanks. I will check it again.
bkrantz
Jun 12 2021, 09:19 PM
Test in the dark, with the original incandescent bulb.
bkrantz
Jun 13 2021, 07:14 PM
I took the light out one more time to adjust the fit, and decided to see what it would look like polished. First some 600 grit.
bkrantz
Jun 13 2021, 07:15 PM
Then 800 grit.
bkrantz
Then black polish compound.
bkrantz
Jun 13 2021, 07:16 PM
Then white polishing compound.
bkrantz
Jun 13 2021, 07:17 PM
Finally, sealant.
bkrantz
Here's the results. Comments?
bkrantz
Jun 13 2021, 07:20 PM
A first test fit of the custom rear bulkhead cover, sourced from rennspd on eBay. Looks pretty good.
bkrantz
Jun 13 2021, 07:23 PM
But first, time to install the interior vinyl pieces.
bkrantz
Test fitting the left side tunnel cover.
bkrantz
Jun 13 2021, 07:24 PM
Then masking off for adhesive spray.
bkrantz
Jun 13 2021, 07:25 PM
I used more of this, same as I used on the targa vinyl.
bkrantz
Jun 13 2021, 07:26 PM
Tunnel side cover pieces in place.
bkrantz
Jun 13 2021, 07:28 PM
And then the cross member cover pieces.
I will probably not use the other vinyl pieces that go behind and next to the seat belt retractors, since the custom perlon panel covers those areas.
Puebloswatcop
Jun 14 2021, 06:45 PM
QUOTE(bkrantz @ Jun 13 2021, 06:17 PM)
I love the polished look and I think the dash light idea was fantastic. It gives function to the ashtray area which would otherwise go unused. Great job
tygaboy
Jun 14 2021, 06:53 PM
QUOTE(Puebloswatcop @ Jun 14 2021, 05:45 PM)
Super cool idea!
Only concern is any reflection you may pick up from that polished surface. You can always paint or powder coat it, should that become an issue.
bkrantz
Jun 14 2021, 07:11 PM
QUOTE(tygaboy @ Jun 14 2021, 06:53 PM)
Super cool idea!
Thanks, guys. I will see how it works out. The only remaining question is whether to put anything on it, like a "914" emblem.
bkrantz
Jun 14 2021, 07:13 PM
Yet another update on the ash tray light. I got the LED bulb today.
bkrantz
Jun 14 2021, 07:14 PM
Much whiter and brighter.
bkrantz
Jun 14 2021, 07:15 PM
I also got the replacement headlight pivot, same as the one I broke when it shifted and the motor drive made the lid bind up.
bkrantz
Jun 14 2021, 07:16 PM
Got the pivot installed.
bkrantz
Jun 14 2021, 07:17 PM
Yay, both headlights now go up.
bkrantz
Jun 14 2021, 07:18 PM
And down.
bkrantz
Jun 14 2021, 07:21 PM
I also started fitting the perlon bulkhead cover.
bkrantz
Jun 14 2021, 07:26 PM
To mount the seat belt reels I needed some holes, and got out my trusty punch kit.
bkrantz
Jun 14 2021, 07:27 PM
Two different size holes, for the reel pin and the bolt.
bkrantz
Jun 14 2021, 07:30 PM
Both reels belted in place. The fit looks pretty good, maybe a bit high. And it will take some stretching to get it properly mounted.
bkrantz
Jun 15 2021, 06:53 PM
Today, I mounted the custom cover, starting with masking off and spraying adhesive. Note: it took a second coat to get good stick.
bkrantz
Jun 15 2021, 06:56 PM
Also two coats on the back of the perlon.
bkrantz
Jun 15 2021, 06:58 PM
Here's the cover, glued on.
bkrantz
Jun 15 2021, 07:00 PM
The perlon covers the inside of the B-pillar, including the vent to the door jamb. I think the material is breathable enough so I will not cut an opening and then look for a grill.
bkrantz
Jun 15 2021, 07:01 PM
Seat belt reel in place.
