bkrantz
Jun 23 2021, 07:26 PM
Then new bolts and the retaining washer.
bkrantz
Jun 23 2021, 07:27 PM
After torquing the new bolts, all done with the flywheel.
bkrantz
A few more things crossed off the list.
bkrantz
Jun 24 2021, 07:43 PM
I decided to see if I could make my uncooperative repro door handles work. Lots of measuring and thinking.
bkrantz
Jun 24 2021, 07:44 PM
On the left handle, the out hole was a bit small.
bkrantz
Jun 24 2021, 07:45 PM
I used a "big" drum sander on my Dremel to open up the hole a bit.
bkrantz
Jun 24 2021, 07:47 PM
Then I used a hand file to knock off the sharp edge at the inside end of the main cylinder, and take just a little off the inner 1/8 inch of the cylinder.
bkrantz
Jun 24 2021, 07:49 PM
The cylinder fit OK, but the recess on the inner end of the handle was too deep by about .01 inch, so the cam was binding.
bkrantz
A bit more hand filing.
bkrantz
Jun 24 2021, 07:50 PM
On the right handle, the entire opening for the cylinder was too tight. I used the small drum sander to open it up a bit.
bkrantz
Jun 24 2021, 07:55 PM
After about 2 hours I have both handles working OK. The cylinders are a little notchy to turn, depending on the key I use, but should work.
bkrantz
Jun 25 2021, 07:12 PM
Getting ready to install the gas tank and plumbing. I have some ideas to try.
First, I want to use a metal fuel filter, but can only find 3/8" to 3/8". That means I need to have a separate 3/8" to 1/2" adapter to step up the supply line to feed the pump inlet.
Second, I want to see if I can set the lines so I can access and change the filter from underneath.
Third, I think I will connect the lines to the tank from underneath, with a minimum amount of extra length.
Let's see what will work.
bkrantz
Jun 25 2021, 07:13 PM
Here's the supply line, with a brass adapter to step up from 3/8 to 1/2" hose.
bkrantz
Jun 25 2021, 07:15 PM
Supply line connected to the pump inlet, and the extra fed down trough the access hole (for now.
bkrantz
Jun 25 2021, 07:16 PM
From underneath, the supply line and also the return line from the engine.
bkrantz
Jun 25 2021, 07:17 PM
Fuel filter, attached from underneath. I can imagine being able to replace this in the future.
bkrantz
Jun 25 2021, 07:18 PM
Fuel filter tucked inside, where it will live most of the time.
bkrantz
Jun 25 2021, 07:20 PM
Checking access to the gas tank fittings. This might work.
bkrantz
Jun 25 2021, 07:22 PM
But before installing the tank, I need to repaint the upper part. The radiator shop the boiled it out did not do much prep, and the paint they applied was flaking off in places. Here's the tank after a quick wire brush treatment.
bkrantz
Jun 25 2021, 07:23 PM
Primer.
bkrantz
Jun 25 2021, 07:27 PM
And new paint.
bkrantz
Jun 25 2021, 07:30 PM
While waiting for paint to fully dry, I refilled the charcoal canister. A few months ago, I drilled 1" holes in each end to empty the original charcoal.
bkrantz
Jun 25 2021, 07:31 PM
Here's the new charcoal. The pellets are a bit bigger than stock, but should work.
bkrantz
Jun 25 2021, 07:32 PM
With both internal baffle plates in place, I filled the canister.
bkrantz
Rubber plug in the fill end.
bkrantz
Jun 25 2021, 07:33 PM
Here's the spring that keeps pressure on the end baffle to compact the charcoal.
bkrantz
Jun 25 2021, 07:34 PM
Feeding into the hole.
bkrantz
And then shoved over to the middle of the space.
bkrantz
Jun 25 2021, 07:35 PM
Second rubber plug.
bkrantz
Ready to use.
bkrantz
Jun 26 2021, 07:29 PM
Here's all the stuff that goes on the tank. Some of this needs prep.
bkrantz
Jun 26 2021, 07:30 PM
I cleaned paint and undercoating from the felt pads. If I use these, I will try soaking them in some kinds of water-repellant lube. The retaining band sections were powder-coated.
bkrantz
Jun 26 2021, 07:31 PM
Rear strap half installed.
bkrantz
Jun 26 2021, 07:32 PM
Also powder-coated: the filler neck and expansion tank.
bkrantz
Jun 26 2021, 07:33 PM
New gasket for the fuel lever sender.
bkrantz
Jun 26 2021, 07:34 PM
Sender installed. The bolt spacing is not even, so it goes in only one way.
bkrantz
Filler neck, with another new gasket.
bkrantz
Jun 26 2021, 07:35 PM
I replaced the gasket in the cap a while ago.
bkrantz
Jun 26 2021, 07:36 PM
Cap in place.
bkrantz
Jun 26 2021, 07:38 PM
Lower tank connections and hardware, including a new screen and copper gaskets.
bkrantz
Jun 26 2021, 07:40 PM
Fittings in place, but loose for now.
bkrantz
Jun 26 2021, 07:42 PM
I dropped the tank in, but can't install it yet since I took the cowl braces back to the paint shop.
bkrantz
Jun 26 2021, 07:45 PM
View from the underneath.
bkrantz
Jun 26 2021, 07:47 PM
I progressively trimmed the fuel lines, and got them slipped on to the tank fittings. No clamps yet.
bkrantz
Jun 27 2021, 06:33 PM
Back to engine work today, lots of time but not many photos.
I made retaining bars to hold the cylinders in place, in prep for measuring the deck height. I made the bars from aluminum angle, so no less chance of marring the cylinder seating surface. And I made spacers from PVC pipe.
bkrantz
Jun 27 2021, 06:36 PM
Before mounting the cylinders I had to re-install the pistons, and got out my ring compressor.
bkrantz
Jun 27 2021, 06:38 PM
P&C numbers 1 and 2 mounted for measurement, no cylinder base gasket.
bkrantz
Jun 27 2021, 06:39 PM
A quick look at number 2 at TDC. I will do some measuring tomorrow.
bkrantz
Jun 28 2021, 07:08 PM
This arrived today, from Mario at the Dub Shop: complete EFI and ignition system.
djway
Jun 28 2021, 10:34 PM
