bkrantz
Jul 4 2021, 08:57 PM
I used a bit of heat to try to make a more defined bend just below the overflow fitting.
bkrantz
Jul 4 2021, 08:59 PM
I have not checked the latest list in a while. Looks like slow progress.
bkrantz
Jul 5 2021, 07:40 PM
Back to soft stuff. This is PVC edge trim (from J&J Auto Fabrics).
bkrantz
Jul 5 2021, 07:41 PM
This edge measures 1/8 x 3/4".
bkrantz
Jul 5 2021, 07:43 PM
I spread the opening to make it possible to insert the soft perlon panel cut edge.
bkrantz
Jul 5 2021, 07:44 PM
The other ingredient: 3/4" 3M adhesive tape.
bkrantz
Jul 5 2021, 07:45 PM
Step 1: run the 3M tape along the lower edge of the glass.
bkrantz
Jul 5 2021, 07:47 PM
Step 2: Get the PVC edging on the perlon cut edge, and try to make it even (not shown).
Step 3: Pull the covering off the tape and stick the edging in place.
bkrantz
Jul 5 2021, 07:48 PM
I like it.
bkrantz
Jul 5 2021, 07:49 PM
With the edge in place, I could install the side targa pads.
bkrantz
Jul 5 2021, 07:58 PM
Then I got out the seat belt hardware. This is the kit for mounting the shoulder yokes.
bkrantz
Jul 5 2021, 08:00 PM
Here's the order: bolt-plastic washer-yoke-plastic washer-large metal washer-metal spacer.
bkrantz
Jul 5 2021, 08:02 PM
Yoke mounted on the left side.
bkrantz
Jul 5 2021, 08:03 PM
And the plastic cover.
bkrantz
Jul 5 2021, 08:07 PM
Now that the back panel is done, I can start on the carpet set. This one is from Performance 900 Porsche interiors.
djway
Jul 6 2021, 12:32 AM
When I had my case work done the only thing removed were the head studs so they could deck it. Did your shop tell you to do all that?
I was at J&J not to long ago, the family that has had it forever is no longer there.
bkrantz
Jul 6 2021, 07:14 PM
I will almost certainly need to ship my case for machining. And I did not trust my packing or the carrier to keep any studs from damage.
bkrantz
Jul 6 2021, 07:18 PM
Carpet day1.
I got out my contact adhesive. Brush-on for the car interior, and spray-on for the back side of the carpet.
bkrantz
Jul 6 2021, 07:19 PM
First piece: the small section that goes above the pedals.
bkrantz
Jul 6 2021, 07:20 PM
In place.
bkrantz
Jul 6 2021, 07:21 PM
Then the left fender well cover.
bkrantz
Jul 6 2021, 07:22 PM
Pretty smooth.
bkrantz
Jul 6 2021, 07:24 PM
Passenger footwell and right fender well. I cut the opening to mount around the steering shaft.
bkrantz
Jul 6 2021, 07:25 PM
With all the complex shapes, I could not avoid some wrinkles. But the center console will hide those.
bkrantz
Jul 6 2021, 07:27 PM
Front tunnel cover. I decided to trim it around the shifter flange.
bkrantz
Jul 6 2021, 07:28 PM
A bit fiddly, but done.
Morph914
Jul 6 2021, 08:33 PM
Nice job! I have done all mine except the center tunnel piece. I am waiting until all my electrical issues are straitened out before putting that piece and the center counsel in.
Love seeing your progress, keep it coming!
Cheers,
John
bkrantz
Jul 7 2021, 08:09 PM
Carpet day 2!
Right sill piece.
bkrantz
Jul 7 2021, 08:10 PM
Installed, pretty straight.
bkrantz
Jul 7 2021, 08:11 PM
Left sill piece.
bkrantz
Jul 7 2021, 08:13 PM
The left sill challenge: the hand brake indentation, plus the brake mounting stuff.
bkrantz
Jul 7 2021, 08:14 PM
Initial placement. I decided I want the carpet rows to be straight on top of the sill.
bkrantz
Jul 7 2021, 08:16 PM
Now to get the carpet stretched a bit, and stuck into the recess.
bkrantz
Getting there.
bkrantz
Jul 7 2021, 08:18 PM
Bottom pieces placed for visual check. I plan to use velcro on these.
bkrantz
Jul 7 2021, 08:20 PM
New GO pedal.
bkrantz
Jul 7 2021, 08:21 PM
Installed. Note: bolts can't be longer that 12 mm.
bkrantz
Jul 7 2021, 08:23 PM
Replacement pedal board, with some new hardware. The original board on my car was a bit curvy.
bkrantz
Jul 7 2021, 08:24 PM
Board installed.
bkrantz
Jul 7 2021, 08:25 PM
And carpet, too.
bkrantz
Jul 7 2021, 08:26 PM
Now for seat belts.
bkrantz
Fancy.
djway
Jul 7 2021, 09:08 PM
Love that new car smell
Arno914
Jul 8 2021, 03:27 AM
Great work! And great attention to detail, even the clamps to hold the carpet in place are yellow like your car.
Cairo94507
Jul 8 2021, 07:12 AM
Excellent carpet install - not a surprise.
kroelofsen
Jul 8 2021, 10:00 AM
envy…
bkrantz
Jul 8 2021, 07:50 PM
QUOTE(Arno914 @ Jul 8 2021, 03:27 AM)
Plus the heat gun on the floor. I used that a VERY little bit on the carpet before clamping.
bkrantz
Jul 8 2021, 07:51 PM
I could not resist seeing how it looks with the center console. I had that recovered last year.
bkrantz
Jul 8 2021, 07:52 PM
Then I got out all the brake lever parts.
bkrantz
Jul 8 2021, 07:54 PM
Short cable, equalizer, and spring installed.
