bkrantz
Jul 8 2021, 07:56 PM
New cables inserted from the engine side. These will get adjusted later.
bkrantz
Jul 8 2021, 07:57 PM
Cable ends on the equalizer.
bkrantz
Jul 8 2021, 07:59 PM
The screw for the cover was interfering with the spring, so I cut it short.
bkrantz
Jul 8 2021, 08:00 PM
Handle done.
bkrantz
Jul 9 2021, 07:37 PM
While thinking about the interior, I placed the center arm rest.
bkrantz
Jul 9 2021, 07:38 PM
Have to do something to cover the exposed bit of tunnel.
bkrantz
Jul 9 2021, 07:40 PM
And then I got out the seat mounting stuff.
bkrantz
Jul 9 2021, 07:42 PM
Paint on the frames looks sad, so I took these apart, and to the powder coat shop.
bkrantz
Jul 9 2021, 07:43 PM
The rails just need some clean-up (and new handles).
bkrantz
Jul 9 2021, 07:44 PM
Shiny seat tilt teeth.
bkrantz
Jul 9 2021, 07:45 PM
More little parts installed.
raynekat
Jul 9 2021, 08:31 PM
QUOTE(bkrantz @ Jul 9 2021, 06:40 PM)
Bob....make sure to tell the powder coater where not to powder coat. Don't make the same mistake I did. That involved hours of sanding/filing/grinding that blasted hard powder coating off of the sliding surfaces. Uggh
Your car and work look incredible.
Dion
Jul 9 2021, 09:11 PM
Fantastic, just fantastic work and progress.
Morph914
Jul 9 2021, 09:30 PM
Killing it! Making great progress
bkrantz
Jul 10 2021, 07:26 PM
Thanks, guys. Progress on the body, but still stalled on the motor.
bkrantz
Jul 10 2021, 07:28 PM
To hide the tunnel top exposed behind the arm rest, I made a small cover. I found a small scrap piece of 1/8" masonite.
bkrantz
Jul 10 2021, 07:29 PM
And a scrap of vinyl on top, and wrapped over the side edges.
bkrantz
Cover in place.
bkrantz
Jul 10 2021, 07:30 PM
Better.
bkrantz
Jul 10 2021, 07:34 PM
After that, I got ready to install the gas tank. I finally found some Euro style hose clamps (20 mm) big enough for 1/2" hose. (And not use the American worm drive clamps on fuel lines, as spotted by a couple of you guys.)
bkrantz
Jul 10 2021, 07:38 PM
All the plumbing is now in place: tank supply to filter to pump to feed line in tunnel, and return line in tunnel to tank.
bkrantz
Jul 10 2021, 07:40 PM
I did re-use the stock felt pads, but soaked in rust prevent lube.
bkrantz
Jul 10 2021, 07:43 PM
I also rehabbed the over-flow drain tube. The new hose I got was too large to feed out the bottom hole. The old tube is still flexible, just stained from the damned PO undercoating.
bkrantz
Overflow tube in place.
bkrantz
Jul 10 2021, 07:45 PM
Tank "dropped" in. This was more fiddly than I expected, to get the tank seated evenly and all the way in.
bkrantz
Jul 10 2021, 07:46 PM
Overflow hose connected.
bkrantz
Jul 10 2021, 07:47 PM
And hoses connected to tank fittings.
bkrantz
Jul 10 2021, 07:48 PM
Fuel level sender plug (with a little bit of edging to protect the wires).
bkrantz
Jul 10 2021, 07:49 PM
And finally, the hold-down clamp.
Puebloswatcop
Jul 11 2021, 08:12 AM
Looks absolutely fabulous Bob.
bkrantz
Jul 11 2021, 06:37 PM
Just some little stuff today. I opened the bag with new trunk hardware, all from 914 Rubber.
bkrantz
Jul 11 2021, 06:38 PM
Front of the trunk.
bkrantz
Jul 11 2021, 06:39 PM
And rear.
bkrantz
Jul 11 2021, 06:41 PM
I also got out my rehabbed door strikers and installed those.
bkrantz
Jul 11 2021, 06:42 PM
Finally, I found my new hardware for the parking brake cables.
bkrantz
Jul 11 2021, 06:44 PM
Step 1: swear at the rubber boots to help ease them over the clevis.
bkrantz
Jul 11 2021, 06:45 PM
Step 2: swear at the retaining clip until it fully seats on the cable ferrule.
Parking brakes work!
euro911
Jul 11 2021, 11:28 PM
QUOTE(bkrantz @ Jul 10 2021, 06:30 PM)
Better.
Looks good, Bob, but didn't your carpet kit come with a small piece to cover that spot ?
raynekat
Jul 12 2021, 08:53 PM
QUOTE(euro911 @ Jul 11 2021, 10:28 PM)
Better.
Most would not have that small piece.
I put together my own fix on my car.
bkrantz
Jul 12 2021, 09:40 PM
QUOTE(raynekat @ Jul 12 2021, 08:53 PM)
Better.
With the stock padded back panel, that spot is not exposed. It shows how much space the stock panel occupies, and gaining that space was part of my motivation for the carpet substitute.
Doug, what did you do?
raynekat
Jul 13 2021, 01:40 AM
QUOTE(bkrantz @ Jul 12 2021, 08:40 PM)
Think I just added some grey perlon in there.
I'll check the pics....
raynekat
Jul 13 2021, 01:46 AM
After further review....maybe nothing.
With the backpad in there and the different style center tray thingy, you don't see much.
Click to view attachment Bet you don't have full length carpets under the seats...huh?
bkrantz
Jul 13 2021, 10:41 PM
QUOTE(raynekat @ Jul 13 2021, 01:46 AM)
Yup, the stock bulkhead pad obscures that space.
Yeah, my midget carpets only cover the area under the rear half of the seats. You win.
bkrantz
Jul 16 2021, 06:56 PM
I finally got back to completing the carpet installation, especially for the main footwell pieces.
Here is the driver's side, carpet piece out, and too much and irregular projection of the side pieces onto the floor.
bkrantz
Jul 16 2021, 06:57 PM
I trimmed the side pieces a bit, and neatened up the corners.
bkrantz
Jul 16 2021, 06:59 PM
To hold the main carpet piece in place, I got this industrial strength Velcro. I left out the floor studs since I did not want big grommets in the carpet. But I still want to remove the main pieces easily.
bkrantz
Jul 16 2021, 07:03 PM
I stuck the fuzzy side to the floor. The adhesive is very strong, and sticks well--including to the back side of the carpet.
bkrantz
Jul 16 2021, 07:05 PM
I then placed the hook side onto the fuzzy strip, and took off the adhesive backing. This way I could place the carpet properly, and the Velcro would be lined up.
bkrantz
Jul 16 2021, 07:06 PM
Carpet in place, and stuck to the Velcro.
bkrantz
Jul 16 2021, 07:07 PM
I put some weight on top, to make sure the adhesive sets tightly.
