bkrantz
Aug 4 2021, 09:18 PM
With the gears out of the way, off with the old bearing...
bkrantz
And on with the new.
bkrantz
Aug 4 2021, 09:20 PM
Then a quick bake in the toaster oven to heat the gear, so it literally slides on.
bkrantz
Aug 4 2021, 09:21 PM
Plus the spacer, distributor gear, and cir-clip. The crank is ready.
bkrantz
Before installing the rest of the new bearings and crank, I remembered the bearing pins.
bkrantz
Aug 4 2021, 09:22 PM
The the #2 bearing halves in both case halves.
bkrantz
Aug 4 2021, 09:23 PM
I dropped the crank in place. No camshaft or other stuff now.
bkrantz
Aug 4 2021, 09:25 PM
And then bolted the other side in place. The crank spins easy, so I think I am ready to install the pistons and cylinders and see about deck height.
bkrantz
Aug 5 2021, 07:39 PM
I took advantage of my son's visit, and opened the body part vault (AKA my downstairs closet) and got out the frunk lid.
bkrantz
Aug 5 2021, 07:40 PM
With extra hands, it was easy to bolt the lid to the hinges.
bkrantz
Aug 5 2021, 07:42 PM
We then spent about 30 minutes getting the lid aligned and leveled.
bkrantz
Aug 5 2021, 07:44 PM
Here's the re-plated latch installed.
bkrantz
Aug 5 2021, 07:46 PM
I am pretty happy with how the lid fits, even with the new gasket. The right headlight also looks good, and the left one needs a little work.
djway
Aug 5 2021, 11:37 PM
930cabman
Aug 6 2021, 08:24 AM
Very well documented Bob.
Thanks for posting
bkrantz
Aug 6 2021, 06:23 PM
I had time today to get the pistons and cylinders mounted on the case (again, built with just the crank).
bkrantz
Aug 6 2021, 06:24 PM
Tomorrow, I can get serious about measuring the deck height (again).
bkrantz
Aug 7 2021, 07:35 PM
No pictures, but I made a first round of deck height measurements today. I found a range of .037 to .041. That's in the target range I want.
930cabman
Aug 8 2021, 04:57 PM
QUOTE(bkrantz @ Aug 7 2021, 07:35 PM)
Great progress Bob, will you be using a "head gasket"
bkrantz
Aug 8 2021, 07:09 PM
Based on what I hear from my vendors and others on 914World, no.
bkrantz
Aug 8 2021, 07:12 PM
I finished deck height and other measurements. Taking my time with many repeats, I got deck heights of .036 to 0.38 (and a few times .040). This sounds like a minimum.
Once done measuring, I took off the cylinders and opened the case again, so I can build the engine for real.
djway
Aug 8 2021, 10:09 PM
I like that red sealant you use. I have been using it to seal up some leaks and it has worked great.
bkrantz
Aug 9 2021, 06:39 PM
Engine build 2 continued.
Here's the cam shaft (Web Cams #86) and bearings, including the second thrust bearing.
bkrantz
Aug 9 2021, 06:41 PM
Cam bearings and shaft installed in the right half. The blue tape is a reminder to install the cam plug when I put the case halves together.
bkrantz
Aug 9 2021, 06:42 PM
Getting the left half ready. Here are the cam bearings installed.
bkrantz
Aug 9 2021, 06:43 PM
And the oil pick-up.
bkrantz
And the baffle plate with edge seals.
bkrantz
Aug 9 2021, 06:45 PM
I took the opportunity to check the oil pump clearance again.
bkrantz
Aug 9 2021, 06:46 PM
I got at least .030" between the back of the pump case and the cam gear bolts, without a gasket.
bkrantz
Aug 11 2021, 06:45 PM
Time to put the case together for the 3rd (4th?) time. And this time I have switched to 574 sealant.
bkrantz
Aug 11 2021, 06:47 PM
Right case half with a thin smear of sealant, ready for the through-bolts (also with a bit of sealant this time).
bkrantz
Aug 11 2021, 06:49 PM
All bolted together and torqued up. Now I need my new cylinder heads--more about them later.
bkrantz
Aug 11 2021, 06:53 PM
Meanwhile, I got started on another project. This is the hidden system, based on a Clarion CMS20.
bkrantz
Aug 11 2021, 06:55 PM
The main box is pretty light and compact, and provides AM-FM and both USB and Bluetooth streaming, and can be mounted remotely. The control box connects via cable.
bkrantz
Aug 11 2021, 06:56 PM
My plan so far: mount the remote box inside the center console, behind the gauges.
bkrantz
Aug 11 2021, 06:58 PM
This should have plenty of clearance.
djway
Aug 11 2021, 09:20 PM
first song you play must be Mellow Yellow by Donovan
bkrantz
Aug 12 2021, 08:43 PM
To mount the control in the arm rest I had to punch a hole in the bottom big enough for the cable plug.
bkrantz
Aug 12 2021, 08:45 PM
Another chance to use my industrial Velcro.
bkrantz
Aug 12 2021, 08:46 PM
Another test fit for the console with hidden head unit.
bkrantz
Aug 12 2021, 08:47 PM
And the arm rest with control unit.
bkrantz
Aug 13 2021, 07:39 PM
The control box in the arm rest feels a little wobbly, and so I made a brace to support the rear half. This will also keep stuff in the storage area from rolling forward under the control (and falling out of the hole I cut in the bottom). The quick "satin" paint job turned out too shiny. I need to find a scrap of black vinyl.
bkrantz
Aug 13 2021, 07:40 PM
I also installed the gauges in the center panel, so that will be ready once I have the sound system wiring done.
djway
Aug 13 2021, 09:11 PM
May I ask why you changed to a different case sealant?
bkrantz
Aug 14 2021, 09:31 PM
QUOTE(djway @ Aug 13 2021, 09:11 PM)
The Permatex was not setting up fully where not clamped and removed from oxygen. I found a few large blobs that spilled from the seam on the inside of the case, and I was concerned they would end up in some small oil passage.
bkrantz
Aug 14 2021, 09:34 PM
First today, a bit more work on the interior. Here is the arm rest brace below the Clarion control box. Still too shiny.
bkrantz
Aug 14 2021, 09:35 PM
I re-installed the center console, including the bracket that mounts to the underside of the dash.
bkrantz
Aug 14 2021, 09:36 PM
Then I got back to work on my engine re-rebuild. To set the crank axial play I got out the shims that worked for the first rebuild.
bkrantz
Aug 14 2021, 09:39 PM
I started with the two original shims that worked last time. But the measured play of .012" means I need a third shim of .008". I don't have that, and I don't think its available.
bkrantz
Aug 14 2021, 09:40 PM
So I switched to the two new shims I have, that are the thinnest in my collection. I measured .016" of play, so I need a .012" shim.
