bkrantz
Aug 28 2021, 07:57 PM
Cover installed, with new sealing nuts.
bkrantz
Aug 28 2021, 07:59 PM
And then the impeller hub and crank nose seal.
bkrantz
Aug 28 2021, 08:00 PM
Before installing the hub, I dressed the sealing surface with some emery paper.
bkrantz
Aug 28 2021, 08:01 PM
I also cleaned up the small Woodruff key.
bkrantz
Aug 28 2021, 08:02 PM
Seal and hub installed.
930cabman
Aug 29 2021, 10:32 AM
Bob, what grit did you use to clean the sealing surface of the hub? and did you use a "seal installer"
thanks
iankarr
Aug 29 2021, 10:52 AM
Did you put the o-ring around the nose of the crank before installing the seal? Just backing ya up since i don't see it in the parts pic
bkrantz
Aug 29 2021, 07:45 PM
QUOTE(930cabman @ Aug 29 2021, 10:32 AM)
thanks
I used some 1000 grit emery paper. And then rinsed the hub with solvent.
For the installer, I used a Jeep hub socket.
bkrantz
Aug 29 2021, 08:08 PM
QUOTE(iankarr @ Aug 29 2021, 10:52 AM)
Thanks for the reminder, Ian--I forgot the O-ring. I think I had it for the first build attempt, but lost it in the shuffle. I just ordered a new one.
I owe you one!
bkrantz
Aug 29 2021, 08:12 PM
I also realized I forgot a couple of the oil galley plugs. Here are the two galleys on the side of the oil cooler mounting flange.
bkrantz
Aug 29 2021, 08:13 PM
And the remaining NPT plugs in the kit.
bkrantz
Aug 29 2021, 08:14 PM
After some thread sealant...
bkrantz
Both plugs are in place.
bkrantz
Aug 29 2021, 08:16 PM
Now I have one very small plug left over. I don't see any of the small galleys that were opened and threaded.
bkrantz
Aug 29 2021, 08:17 PM
My next project is creating and installing a new oil dip stick tube, since the original was pretty beat up.
bkrantz
Aug 29 2021, 08:18 PM
I bought a 1mm and then a 0.5mm wall tube, both 8mm OD (original on the right).
bkrantz
Aug 29 2021, 08:19 PM
That was based on my measurement of the original tube main section.
bkrantz
Aug 29 2021, 08:21 PM
But the part that inserts into the engine case is larger, about 8.4mm. Now I have to figure out how to expand the base of the tubing.
930cabman
Aug 30 2021, 07:16 AM
QUOTE(bkrantz @ Aug 29 2021, 08:16 PM)
Probably 1/8" NPT, would be installed on the face of the case near the dip stick tube. Take your time, don't get too anxious and miss a step or two.
Thanks for posting, many of us are following your build
iankarr
Aug 30 2021, 07:54 AM
Got your six
though in this group that could take on other meanings! Your build is spectacular.
QUOTE(bkrantz @ Aug 29 2021, 10:08 PM)
I owe you one!
bkrantz
Aug 31 2021, 08:39 PM
QUOTE(930cabman @ Aug 30 2021, 07:16 AM)
Thanks--as soon as I get back to my garage I will check that.
930cabman
Sep 3 2021, 05:50 AM
Bob,
have a look at post # 3605, it would be directly to the left of the fan hub. The factory plug appears to still be in place.
bkrantz
Sep 3 2021, 07:36 PM
QUOTE(930cabman @ Sep 3 2021, 05:50 AM)
Bob,
Yes. As far as I can tell, all the very small plugs are still in place (and look solid).
raynekat
Sep 3 2021, 08:51 PM
Bob....did anyone ever tell you that you act like an engineer?
Ha! I almost forgot, you are an engineer.
Love watching you get into the minutia of it all.
Well done man.
bkrantz
Sep 4 2021, 07:35 PM
QUOTE(raynekat @ Sep 3 2021, 08:51 PM)
Well done man.
To be fair to all actual engineers, I am only a scientist by training. But maybe an aspiring engineer by compulsion.
bkrantz
Sep 4 2021, 07:37 PM
Speaking of which, I tried again to make my new oil dipstick tube.
Here are two hardened steel rods (from McMaster-Carr): 7.4 and 7.5 mm.
bkrantz
Sep 4 2021, 07:40 PM
Got my bench grinder onto my bench. Some day in my dream shop I will have more bench space.
bkrantz
Sep 4 2021, 07:42 PM
I ground the end of the 7.4 mm rod, so I can use it as a mandrel for the 8.0 mm tubing.
bkrantz
Sep 4 2021, 07:44 PM
I first tried to force the rod into the tubing cold, but that did not work.
So I used a propane torch to heat the rod and tubing.
bkrantz
Sep 4 2021, 07:45 PM
That worked, especially after I refined my technique to heat the tubing a small section at a time.
bkrantz
Sep 4 2021, 07:47 PM
But the end result was too much enlargement. I need the end of the dipstick tube to have an OD of about 7.35 mm, but got 7.45.
So back online to order a smaller diameter rod.
bkrantz
Sep 5 2021, 08:53 PM
Still waiting for several parts to arrive, so I can fool with some miscellaneous stuff, like the hidden antenna that will connect to my hidden audio system. I have no idea how well this will work, but I will find out eventually.
bkrantz
Sep 5 2021, 08:54 PM
Here is my current plan: mounting the antenna pad inside the upper corner of the windshield.
bkrantz
The wire goes along the A-pillar.
bkrantz
Sep 5 2021, 08:55 PM
And through the gap at the side of the dashboard.
bkrantz
Sep 5 2021, 08:57 PM
I re-installed the A-pllar pad, the left the antenna ready to mount to the windshield. (Reminder: I need to get on sourcing the windshield.)
bkrantz
Sep 5 2021, 08:58 PM
At the bottom end, I connected the antenna lead. And then the harness for the center console gauges.
bkrantz
Sep 5 2021, 09:03 PM
And then I worked on the replacement console panel. I took the custom cover that had been mounted on the original (cracked) panel. Staples in the MDF did not work well, so I decided to use spray adhesive.
bkrantz
Sep 5 2021, 09:04 PM
Not my neatest effort, but I got the vinyl glued on evenly, and the underside edges eventually stuck in the right place.
bkrantz
Sep 5 2021, 09:06 PM
Once everything dries, I will clean up the mess with 3M adhesive remover.
930cabman
Sep 6 2021, 05:15 AM
Looks great, how close is the vinyl to the original, was is readily available?
raynekat
Sep 6 2021, 05:06 PM
Meant to say you're one of them "earth" engineers. Ha
bkrantz
Sep 6 2021, 06:58 PM
QUOTE(930cabman @ Sep 6 2021, 05:15 AM)
Reasonably close. I had the upholstery shop recover all the console pieces, the arm rest, and door panels at the same time, so at least they all match.
bkrantz
QUOTE(raynekat @ Sep 6 2021, 05:06 PM)
Yup, a pebble pup.
bkrantz
Sep 6 2021, 07:00 PM
I cleaned up both sides, first with 3M and then a vinyl cleaner.
bkrantz
Sep 6 2021, 07:01 PM
This should do.
bkrantz
Sep 8 2021, 07:39 PM
I spent some time refining fits. Here is the left headlight after the last quick adjustment--not quite right.
bkrantz
Sep 8 2021, 07:40 PM
This is better, and the best I can do without enlarging some of the mounting holes.
bkrantz
Sep 8 2021, 07:41 PM
I then tackled the sagging hood. Initially, I put the springs in the middle notch.
bkrantz
Sep 8 2021, 07:42 PM
I put my special tool back together, and moved the spring to the "longest" notch.
