bkrantz
Sep 15 2021, 07:36 PM
With the wheel temporarily bolted to the fan hub, its all ready for initial testing.
bkrantz
Sep 16 2021, 07:48 PM
Here's the setup for testing the signal, with 12 V to the sensor, and then a voltmeter across the sensor output lead.
bkrantz
Sep 16 2021, 07:50 PM
Tooth over the sensor, should be under 0.25 V.
bkrantz
Check.
bkrantz
Sep 16 2021, 07:51 PM
Gap over the sensor, should be 12 V.
bkrantz
Sep 16 2021, 07:52 PM
Check (the battery is a bit low).
And I cycled the entire wheel, and got consistent output.
bkrantz
Sep 16 2021, 07:53 PM
Let night, UPS brought my new Hoffman heads, by way of LN Engineering.
bkrantz
Sep 16 2021, 07:54 PM
Very sexy, right?
bkrantz
Sep 16 2021, 07:56 PM
I was going to wait until Saturday, but could not resist. I checked all the fits, and rechecked the deck height, and then started putting the P&C on for real. That includes piston pin retaining clips. First one on the bench is easy.
bkrantz
Sep 16 2021, 07:57 PM
Second one is a bit harder.
bkrantz
Sep 16 2021, 07:59 PM
For mounting the cylinders, I used a thin smear of 5900 at the base.
bkrantz
Sep 16 2021, 08:00 PM
Left head mounted and torqued.
bkrantz
Sep 16 2021, 08:01 PM
More engine!
DRPHIL914
Sep 17 2021, 06:47 AM
looking good! are you doing 96's with those heads? (are those HAM1 heads)
good stuff for sure, i was on the list to get some on his next batch, but he kind of dropped the ball on me and i had to go a different direction. Just got my motor in the car this weekend, good luck to ya ! what is your break in proceedure for cam and bearning break in?
Phil
bkrantz
Sep 17 2021, 07:36 PM
RS+ heads, from LN.
Not sure about break in, I am still thinking about assembly!
bkrantz
Sep 17 2021, 07:43 PM
I got started on the rocker arms today. Here is the kit from Tabari Andrade, who modified my rockers and shaft supports, and supplied new swivel adjusters, shafts, and shims.
bkrantz
Sep 17 2021, 07:44 PM
That includes several shims in various sizes.
bkrantz
Sep 17 2021, 07:45 PM
Here is the first mock-up for cylinder #1, following the rule of having a thick shim to the right of each rocker.
bkrantz
Sep 17 2021, 07:46 PM
First test fit. My goal was to align each rocker just to the right of each valve stem center.
bkrantz
Sep 17 2021, 07:47 PM
It may not look it, but the hole for the adjuster is offset a bit to the right.
bkrantz
Sep 17 2021, 07:48 PM
Here is the initial gap. I iterated on filling the gap with shims and maintaining the slight offset of the rocker.
bkrantz
Sep 17 2021, 07:49 PM
Besides the offset rocker alignment, I aimed for .004" freeplay in the entire stack of rockers and shims.
bkrantz
Sep 17 2021, 07:51 PM
Left side done.
bkrantz
Sep 17 2021, 07:52 PM
And right side.
bkrantz
Sep 17 2021, 07:53 PM
At the end, I used all the new shims except one .004", plus I had to scrounge one of my original rocker shaft shims.
bkrantz
Sep 18 2021, 07:42 PM
Before going further, I did remember that the sheet metal baffles for under the cylinders need to mount before push rod tubes.
bkrantz
Sep 18 2021, 07:43 PM
But I did not remember that the brial cylinders have wider fins, so the baffle edges interfere.
bkrantz
Sep 18 2021, 07:46 PM
So, some quick surgery, using shears to cut to rough clearance.
bkrantz
Sep 18 2021, 07:49 PM
And then the mini drum sander on my Dremel.
bkrantz
Sep 18 2021, 07:50 PM
Getting there.
bkrantz
Sep 18 2021, 07:51 PM
Fits!
bkrantz
Sep 18 2021, 07:53 PM
Time now for lifters!
bkrantz
Cam lube on the end (and assembly lube on the body and bore).
bkrantz
Sep 18 2021, 07:54 PM
Then I dropped the lifters in.
bkrantz
Sep 18 2021, 07:55 PM
And plugged the holes.
bkrantz
Sep 18 2021, 07:58 PM
Now for adjusters, new 10 mm swivel feet. (And old nuts for now.)
bkrantz
Sep 18 2021, 07:59 PM
Adjusters installed.
bkrantz
Sep 18 2021, 08:02 PM
So then I started to learn about push rod tubes and optimizing length. Here is my adjustable rod in the intake for cylinder #1.
bkrantz
Sep 18 2021, 08:06 PM
And my setup for the dial gauge on the valve spring retainer.
bkrantz
Sep 18 2021, 08:09 PM
After some quick trials, I measured .427" lift. Spec lift is .423"
bkrantz
Sep 18 2021, 08:12 PM
And the alignment at half-lift looks good.
bkrantz
Sep 18 2021, 08:13 PM
I have to catch up on keeping the list current.
bkrantz
Sep 19 2021, 07:43 PM
I spent more time today in pushrod hell. See my new thread for that, and my questions.
After I gave up on pushrods for today, I refined my rocker offset and spacers.
bkrantz
Sep 19 2021, 07:45 PM
I also got a gift package from Morph914 (thanks again!).
bkrantz
I was able to install the shift lever rubber boot!
djway
Sep 19 2021, 09:47 PM
Did you get the pushrod tube spacers? I assume you need them since you are measuring for rods.
bkrantz
Sep 20 2021, 09:05 PM
QUOTE(djway @ Sep 19 2021, 09:47 PM)
Not sure what those are--can you elaborate?
bkrantz
Sep 21 2021, 06:57 PM
Still playing with rocker arms and pushrods. I tried using stock rods with washers acting as spacers under the shaft supports.
bkrantz
Sep 22 2021, 07:43 PM
I took a break from pushrods today, and opened the latest package I got from the powder coat shop.
bkrantz
Sep 22 2021, 07:47 PM
Seat bottom frames!
I had them coat everything, including the rails. Before, the fit with the sliders was a little sloppy, so I figured the coating would fill the gaps.
