Puebloswatcop
Dec 8 2021, 08:42 AM
You are almost to "drum roll" time. Can't wait.
bkrantz
Dec 8 2021, 09:18 PM
Thanks, guys. It feels close--but close could be a couple of months.
bkrantz
Dec 8 2021, 09:27 PM
I am still sorting out all the new electrical connections. With the new EFI system, the power for the fuel pump comes from the new relay box, that will be in the trunk along with the ECU. I need to get power to the relocated pump, which uses the stock pump wiring (extended to reach the front).
Lots of detective work tells me that pin 12 on the rear plug, on the stock relay board, connects to the pump. I confirmed this by running a lead to pin 12--and the pump runs!
bkrantz
Dec 8 2021, 09:35 PM
More about my wiring plan. I want to modify the 12-pin cable to bridge the new EFI system with the stock car system.
The cable housing is pretty rigid and brittle.
bkrantz
Dec 8 2021, 09:36 PM
I still need the stock 12-pin cable wires for the starter, the back-up switch on the transaxle, and the oil pressure switch. The original leads to the coil will be repurposed to send ignition-on to the new relay box, and to carry the signal to tach.
bkrantz
Dec 8 2021, 09:42 PM
I removed the original lead on pin 12, which supplied power to the supplementary air valve.
bkrantz
Dec 8 2021, 09:43 PM
And I replaced it with a new thicker gauge red wire to feed power for the fuel pump.
bkrantz
Dec 8 2021, 09:44 PM
I checked all the wires and then replaced the brittle covering sections.
bkrantz
Dec 9 2021, 09:54 PM
Back-up light switch leads with terminals replaced (soldered).
bkrantz
Dec 9 2021, 09:56 PM
The rebuilt engine cable with all terminals replaced, and two double-connectors for the fuel pump and the ignition on/tach feed leads. All terminals and connectors soldered on.
bkrantz
Dec 9 2021, 09:58 PM
That should be all the cables and leads, old and new. Now to organize this mess before it goes in the car.
bkrantz
Dec 9 2021, 10:00 PM
Stuff that might help: spark plug wire brackets and cable clamps/hangers.
Cairo94507
Dec 10 2021, 09:54 AM
bkrantz
Dec 10 2021, 08:31 PM
Some more engine details. First, I need to make a way for the intake temp sensor cable to reach inside the air filter.
bkrantz
Dec 10 2021, 08:33 PM
Per Dup Shop design, I notched the base plate.
bkrantz
Dec 10 2021, 08:34 PM
The filter element covers most of the notch. Maybe a dap of silicone for where the wire passes through.
bkrantz
Dec 10 2021, 08:36 PM
Then, I started plumbing the engine vacuum system--still under design. Here is the stock anti-flashback valve.
bkrantz
Dec 10 2021, 08:37 PM
Valve installed in the stock location.
bkrantz
Dec 10 2021, 08:38 PM
Some stock-type 12mm vacuum hose, from Belmetric.
bkrantz
Dec 10 2021, 08:39 PM
Left cylinder head to valve.
bkrantz
Right cylinder head to valve.
bkrantz
Dec 10 2021, 08:41 PM
Now for the small vacuum line, to connect the throttle bodies to the EFI control box and the fuel pressure regulator.
bkrantz
Dec 10 2021, 08:42 PM
I bolted one spark plug wire holder to each side of the rear sheet metal panel.
bkrantz
Dec 10 2021, 08:44 PM
Now starting to think about where to put the control box and the relay box. The trunk is the obvious place, away from wet conditions.
bkrantz
Or maybe like this? Suggestions welcome!
bkrantz
Dec 11 2021, 09:08 PM
More details on the engine while it is still on the stand.
I need vent lines attached to the air filter housing, and got a pair of brass fittings, with 1/2 inch NPT threads. I also got a set of NPT taps. (Always buy more tools!)
bkrantz
Dec 11 2021, 09:11 PM
Speaking of tools, in the back of my ratchet-socket drawer, I found this cross-bar socket driver, that filled in for a large diameter tap handle.
bkrantz
Dec 11 2021, 09:12 PM
Holes drilled and tapped.
bkrantz
Dec 11 2021, 09:13 PM
Fittings installed with sealant.
bkrantz
Dec 11 2021, 09:14 PM
No interference with the filter element.
bkrantz
Dec 11 2021, 09:15 PM
Mounted on the left throttle body.
bkrantz
Dec 11 2021, 09:16 PM
Vacuum/vent line from the cylinder heads via the anti-flashback valve.
bkrantz
Dec 11 2021, 09:18 PM
I found that the notches in the plug wire brackets were too small, and pinching the wires. So I pulled off the plastic dip coating, and then filed the holes larger. I was able to slid the coating back on.
bkrantz
Dec 11 2021, 09:19 PM
I stacked the plug wire brackets with a pair of hose clamps for the fuel lines on both sides .
bkrantz
Dec 11 2021, 09:20 PM
For now, the fuel lines and plug wires are done.
bkrantz
Dec 12 2021, 07:42 PM
Here's my SS muffler from Ben Macfarland. I need to install a SS bung for the O2 sensor. The muffler might not be ideal, since it is a bit downstream from the combustion chambers, but it is the first location where the exhaust from all 4 cylinders will mix.
bkrantz
Dec 12 2021, 07:43 PM
I chose a location as far towards the center as possible, but not in the way of the muffler bracket.
Then I got out a 1 inch hole saw, and mounted the muffler on the press.
bkrantz
Dec 12 2021, 07:45 PM
Ready for welding.
bkrantz
Dec 12 2021, 07:48 PM
I then started the transfer of the engine from the stand onto jack stands. This turned out to be a logic puzzle as well as mechanical process.
First, I got out the engine support bar, from the almost depleted stock of powder-coated parts.
bkrantz
Dec 12 2021, 07:49 PM
Bolted onto engine rubber mounts.
bkrantz
Dec 12 2021, 07:51 PM
Here's part one of my two step process. Given the jacks and other stuff I have, I had to first take the weight off the stand, and then lower the engine as much as possible, i.e. about half-way. I made some scaffolding, and put my Fuchs wheels to work (purists look away).
bkrantz
Dec 12 2021, 07:55 PM
After removing the stand, I lowered the engine so the support bar and the stand pivot rested on jack stands. I then pulled out my "scaffolding" and repositioned the jack now on the floor.
bkrantz
Dec 12 2021, 07:58 PM
With the weight on the jack again, I added an angle iron piece to support the back of the engine.
bkrantz
Dec 12 2021, 08:00 PM
I will leave the jack in place as backup, until the trans is attached and supported.
bkrantz
Dec 12 2021, 08:01 PM
Last task today: unbolt the engine stand mount from the case. Ready for a clutch!
nivekdodge
Dec 12 2021, 08:29 PM
QUOTE(bkrantz @ Dec 12 2021, 09:01 PM)
If you have an engine hoist is there a safe place to bolt a chain?
Puebloswatcop
Dec 13 2021, 05:54 PM
QUOTE(bkrantz @ Dec 10 2021, 08:44 PM)
Looking at the possibility of having to remove any connections i think the first picture makes more sense in mounting the control box...... But after looking at the pictures again I see that the ports are blocked either way....Maybe mount both on the upper part of the wall so they arent blocked by the jack or the inner fender.....
bkrantz
Dec 13 2021, 08:10 PM
QUOTE(nivekdodge @ Dec 12 2021, 07:29 PM)
I have one (in pieces, stashed under my big work bench). But I thought by the time I could rig up a safe attachment method and assemble the hoist, I could get the job done with my motorcycle lift.
bkrantz
Dec 13 2021, 08:22 PM
QUOTE(Puebloswatcop @ Dec 13 2021, 04:54 PM)
I am still pondering the best location. I should need to connect to the serial port during set up and tuning, so the jack would not be in the way most of the time.
bkrantz
Dec 13 2021, 08:26 PM
Everything (almost) I need to get the trans ready and mounted to the engine.
