bkrantz
Jan 17 2022, 08:03 PM
New sensor (on the right) ready to install and test--but dinner time.
bkrantz
Jan 26 2022, 07:46 PM
Well, dinner turned into an extended absence. But I am back!
Lots of stuff delivered while I was gone, including a 3 ft length of 5 mm hex. Why?
bkrantz
Jan 26 2022, 07:50 PM
This is a tool to finally repair my hydraulic press. The hex has to reach inside a 12 inch long spring in order to screw down the end retaining Allen bolt. Even the extra-long Allen wrench I have will not reach.
bkrantz
Jan 26 2022, 07:52 PM
With the spring bolted to the bottom of the piston, and the piston inside the cylinder, the next trick is to pull the spring far enough to screw in the upper anchor. Definitely a three-handed job.
bkrantz
Jan 26 2022, 07:53 PM
Somehow I got the second Allen bolt in with only two hands.
bkrantz
Jan 26 2022, 07:54 PM
Piston and cylinder ready.
bkrantz
Jan 26 2022, 07:56 PM
Nice to have the press working again--especially the auto return.
bkrantz
Jan 26 2022, 07:58 PM
Back to working on the 914. A warm-up with dual outlet for the heater blower.
bkrantz
Jan 26 2022, 08:04 PM
Then I moved the wire leads from the Hall sensor back to where they were in December, to match the one-page diagram of the lead connections (and confirmed by Mario).
bkrantz
Jan 26 2022, 08:05 PM
Then it was time to install the replacement throttle position sensor.
bkrantz
Jan 26 2022, 08:09 PM
It works! A quick calibration, and now I have consistent 0 to 100% opening.
I then tested the ignition spark with a spare plug, and now have a healthy spark with the engine cranking.
While on a roll I hooked up my timing light and tried to check the static timing, again with the engine cranking, but could not get a consistent light flash.
bkrantz
Jan 28 2022, 08:08 PM
Just a few minutes to play 914 today. I did stop by a tire shop to have one tire removed, from the wheel that will be my spare. This rim has the worst curb rash.
bkrantz
Jan 28 2022, 08:09 PM
The inside has many years of road crud.
bkrantz
Jan 28 2022, 08:10 PM
After a quick clean, first with detergent and then Simple Green. Still some work to do.
bkrantz
Jan 29 2022, 08:44 PM
Some special stuff.
bkrantz
Calendar installed easily--works great.
bkrantz
Jan 29 2022, 08:46 PM
Andmore new stuff, mostly small parts.
bkrantz
Jan 29 2022, 08:47 PM
Back under the car, with a new barrel clamp.
bkrantz
Jan 29 2022, 08:49 PM
That goes on the left heat control box.
bkrantz
Jan 29 2022, 08:50 PM
Then a length of high temp hose, cut down to fit.
bkrantz
Jan 29 2022, 08:52 PM
That connects the control box and feed to the long duct on the left.
bkrantz
Jan 29 2022, 08:53 PM
And another on the right. That completes all the heat system ducting, at least under the car.
bkrantz
Jan 29 2022, 08:54 PM
Cross another task off the list!
bkrantz
Jan 29 2022, 08:58 PM
Another detail: sealing boot for the clutch cable.
bkrantz
Jan 29 2022, 08:59 PM
Boot installed.
bkrantz
Jan 29 2022, 09:00 PM
While under the car, I was reminded that the speedo cable did not have a boot, so I got out some 3M rubber sealing tape.
bkrantz
Jan 29 2022, 09:01 PM
Instant boot.
bkrantz
Jan 29 2022, 09:06 PM
Another new boot: for the shift rod. The old one was essentially rigid.
bkrantz
Jan 29 2022, 09:07 PM
To get that installed, I had to detach the rear shift rod at both ends. Hope this is worth it!
bkrantz
Jan 30 2022, 08:37 PM
Time to start another task: filling and bleeding the brake system. I bought almost all components, including new stainless steel lines and rebuilt calipers from PMB. The system has been on the car complete for a year, but not filled.
I started with a simple plan, and tried gravity bleeding.
bkrantz
Jan 30 2022, 08:39 PM
Here's the gravity bleed hose set up on the right rear caliper, with the free end of the hose higher than the reservoir.
bkrantz
Jan 30 2022, 08:42 PM
I filled the reservoir, opened the caliper bleeder, and...nothing.
I gently pumped the brake pedal a few times and the level dropped a little bit, but then stayed the same.
bkrantz
Jan 30 2022, 08:45 PM
So, I next got out the power bleeder, that has been part of my garage kit for about 30 years, with the Porsche reservoir adapter.
bkrantz
Jan 30 2022, 08:47 PM
But the hose is showing its age. For today, I cut off the end with the split and re-attached the cap.
bkrantz
Jan 30 2022, 08:48 PM
Then I could pump (just air) and pressurize the reservoir to about 25 psi.
bkrantz
Jan 30 2022, 08:49 PM
Next problem: a puddle on the floor under the master cylinder.
bkrantz
Jan 30 2022, 08:53 PM
At first I expected to see the supply lines from the reservoir leaking, but they were dry. The (main) leak was from the fitting where the front right line attaches to the banjo fitting. This was actually just finger tight--my bad.
bkrantz
Jan 30 2022, 08:59 PM
So I tightened that loose fitting, pumped up some pressure, and found more leaks.
Now I was worried. I started tracing all the lines and connections, starting at the MC. None were "loose", but I was able to tighten all of them a bit more. When I installed all the lines I tightened them the way I would for "normal" steel brake lines. I think the SS lines need more pressure to seat fully.
bkrantz
Jan 30 2022, 09:00 PM
That included the junction fitting inside the tunnel.
bkrantz
Jan 30 2022, 09:03 PM
I was able to stop all obvious leaks except for where the line feeds into the right rear caliper. Even after what felt like too much torque it still weeped. So I removed the line.
bkrantz
Jan 30 2022, 09:05 PM
A possible problem: the flare on the caliper end is a bit off-center and uneven (it looks worse than the photo shows). Time to step back.
bkrantz
Jan 31 2022, 08:56 PM
Well, sitting overnight revealed a similar leak from the left rear caliper.
bkrantz
Jan 31 2022, 08:58 PM
Just like the right side, the line going in to the caliper is leaking, despite a fair amount of tightening on the fitting.
bkrantz
I pulled the hard line off.
bkrantz
Jan 31 2022, 08:59 PM
And just like on the right side, the flare seems off-center. (Sorry for the fuzzy photo)
bkrantz
Jan 31 2022, 09:02 PM
Meanwhile, I was experimenting with cleaning the original Fuchs wheels. I got most of the ancient wheel weight adhesive off from the inside. And then I got out my new citrus cleaner from Chemical Guys.
bkrantz
Jan 31 2022, 09:04 PM
About 30 minutes with the cleaner and a scotch-bite pad, and the inside is looking good--good enough at least for this wheel, which will be my spare.
bkrantz
Jan 31 2022, 09:05 PM
The outside also cleaned up a bit, but still has the nasty bit of curb rash.
bkrantz
Feb 2 2022, 08:32 PM
Back on the brake lines. According to some reliable sources, stainless steel lines are a bit harder, and might take more effort to get the flares to seat properly. They recommend a process of tightening and loosening a fitting, and repeating 5 or 6 times, before a final tightening.
So, starting at the master cylinder, I applied this technique at every junction.
bkrantz
Feb 2 2022, 08:33 PM
Junction with the tunnel line.
