bkrantz
Apr 18 2020, 08:49 PM
Left headlight box.
bkrantz
Apr 18 2020, 08:50 PM
Detail:
bkrantz
Apr 18 2020, 08:51 PM
Right headlight box:
bkrantz
Apr 18 2020, 08:53 PM
More ugly details:
bkrantz
Apr 18 2020, 08:54 PM
Time for surgical removal. I am trying to minimize replacement.
bkrantz
Apr 18 2020, 08:55 PM
More:
bkrantz
Apr 18 2020, 08:56 PM
And more:
bkrantz
Apr 18 2020, 08:58 PM
The biggest section I removed was the inner side of the front edge. As always, the tools pile up during a job.
bkrantz
Apr 18 2020, 09:00 PM
Today, the hero tool was the Dremel. We will see how long this one lasts.
bkrantz
Apr 19 2020, 08:30 PM
I started piecing the channel back together today, with the new stock from 914 Rubber. Thanks, Mark.
bkrantz
Apr 19 2020, 08:32 PM
The piece cut for the front left corner.
bkrantz
Apr 19 2020, 08:33 PM
I managed to get a bit of curvature, to match the original arc.
bkrantz
Apr 19 2020, 08:34 PM
Fit in place.
bkrantz
Apr 19 2020, 08:36 PM
And welded in. I had pretty good luck with the thin gauge metal edges, even a bit of corrosion.
bkrantz
Apr 19 2020, 08:37 PM
Right front corner piece.
bkrantz
In place.
bkrantz
Apr 19 2020, 08:39 PM
I started to tack weld this, and...the wire ran out. Always at an inconvenient moment, right? I had one more spool in my stock.
bkrantz
Apr 19 2020, 08:40 PM
Back to welding. I can grind these first corner pieces tomorrow, and get on with the next bits.
Baker17
Apr 20 2020, 09:07 PM
Your work is inspiring and will be a reference when I finally start my 914. I have a question though and I am sorry if it is a silly one but here it goes: why didnt you have the shell blasted before you started all the work? It seems to me that it would have been easier to see all the problem areas and would have helped with the welds? Again, this is a question from a soon to be first timer....
PS: You make a very good case for a rotisserie. But it is so expensive....
Cheers
bkrantz
Apr 21 2020, 08:53 PM
My delay in blasting was a combination of poor planning--and not expecting to get this deep. By the time I realized I was into a complete tear down, it was too late to get any external sources for paint stripping.
As for the rotisserie, I am hoping that when done I can sell it for a good part of my purchase price (unless my son claims it).
bkrantz
Apr 21 2020, 08:55 PM
Back to work, just an hour yesterday and a couple today. For me, short stints seem to work better for small pieces.
Grinding the first bits from Sunday. Left side:
bkrantz
Apr 21 2020, 08:57 PM
Right side:
bkrantz
Apr 21 2020, 08:58 PM
Next piece for the left side.
bkrantz
Apr 21 2020, 08:59 PM
Welded in place.
bkrantz
Apr 21 2020, 09:00 PM
Same piece for the right side.
bkrantz
Welded in place.
bkrantz
Apr 21 2020, 09:03 PM
Inner corner piece for the right side.
bkrantz
Welded.
bkrantz
Apr 21 2020, 09:04 PM
Last piece for the right side?
bkrantz
Apr 21 2020, 09:05 PM
Welded.
bkrantz
Apr 21 2020, 09:06 PM
Here's the right side, almost done.
bkrantz
Apr 22 2020, 07:39 PM
First, I caught up with grinding the pieces from yesterday.
bkrantz
Apr 22 2020, 07:40 PM
More grinding.
bkrantz
Apr 22 2020, 07:41 PM
And more grinding.
bkrantz
Apr 22 2020, 07:44 PM
The last bit is the inner edge of the channel all along the front. I had to cut down the stock width of the L, and give it the same curvature as the front of the car.
bkrantz
Apr 22 2020, 07:45 PM
Got it tacked in place before quitting time.
bkrantz
Apr 23 2020, 08:11 PM
I finished up the frunk channel today. Before final welding along the front, including the latch mounting plate, I made sure I had the same angle across the channel from left to right.
bkrantz
Apr 23 2020, 08:13 PM
Here's the latch welded on. Don't worry, I ground this into something pretty.
bkrantz
Apr 23 2020, 08:16 PM
After welding the front channel "seam" and grinding that.
bkrantz
Apr 23 2020, 08:17 PM
Frunk channel all done, and another item crossed off the list.
bkrantz
Apr 24 2020, 08:33 PM
With the frunk channel done, I switched to the read panel. This was the last bit of bodywork with significant filler (than know of--knock on wood).
Here's the panel before grinding off the filler.
bkrantz
Apr 24 2020, 08:34 PM
And after.
bkrantz
Apr 24 2020, 08:36 PM
Some dents and dings, and holes from the PORSCHE reflector panel installed by a PO.
bkrantz
Apr 24 2020, 08:38 PM
The reflector panel holes will get welded, and the stock holed for the original insignia will get cleaned of bondo.
bkrantz
Apr 24 2020, 08:40 PM
For access to the inside of the panel, I removed the trunk lock mounting plate.
bkrantz
Apr 24 2020, 08:41 PM
Here's the mounting plate. Pretty lumpy.
raynekat
Apr 24 2020, 09:27 PM
QUOTE(bkrantz @ Apr 24 2020, 07:41 PM)
Hey, I like my smashed pototos lumpy.
Looking good there Robert with all your progress.
bkrantz
Apr 25 2020, 08:20 PM
QUOTE(raynekat @ Apr 24 2020, 09:27 PM)
Thanks, Doug. Still thinking positive here, lumps and all.
bkrantz
Apr 25 2020, 08:23 PM
For better access I unbolted the rotisserie rear upright, with the car on jack stands.
bkrantz
Apr 25 2020, 08:24 PM
Now I can see the worst spots.
