jim_hoyland
Oct 17 2019, 06:42 PM
I bought the 5 lug Billet hubs from Brad back in the day. I’m seeking the stud length from someone that has installed or worked with them.
I’m going to add spacers and would like to order longer studs before pulling the hubs.
914Sixer
Oct 17 2019, 07:15 PM
Thinking they were set up for stock 45mm hubs. Just add the thickness of the spacer you are going to use to the 45 mm.
Oct 17 2019, 07:28 PM
Didn’t Mike Mueller design them?
@Mueller
jim_hoyland
Oct 17 2019, 07:53 PM
QUOTE(914Sixer @ Oct 17 2019, 06:15 PM)
Thicker
jim_hoyland
Oct 17 2019, 07:54 PM
QUOTE(mepstein @ Oct 17 2019, 06:28 PM)
@MuellerTried Mike.
Need someone who currently has them....
Oct 17 2019, 07:55 PM
Just add up the thickness of the hub, the thickness of the spacer, the thickness of the wheel center mounting surfaces and add enough to get full thread engagement on the lug nuts you are going to use.
QUOTE(jim_hoyland @ Oct 17 2019, 09:53 PM)
Thicker
Can you just measure the hubs and add the difference from a normal hub.
jcd914
Oct 17 2019, 09:20 PM
The rule of thumb I was taught is, steel on steel you want thread engagement at least equal to the diameter of the stud and steel on aluminum you want 1.5 times the diameter of the stud.
So for a 14mmm stud you want a minimum of 21mm engagement into the aluminum hub and 14mm engagement into the lug nut if it is steel and 21mm of you have aluminum lug nuts.
So 35mm or 42mm plus the thickness of the spacer you're going to use plus the thickness of the wheels you're using. I would include some additional length so I could have more thread engagement than minimum.
What wheels are you running and what spacers are you going to use?
Jim
jim_hoyland
Oct 18 2019, 05:09 AM
QUOTE(jcd914 @ Oct 17 2019, 08:20 PM)
Jim
Thanks: Wheels currently are Fuchs 16 x 6, spacers are 10mm
infraredcalvin
Oct 18 2019, 09:33 PM
I’m not too far from you, met you once at my office in fashion island (I bought something off you, I forget what it was). I have a few sets of different lengths and a few different spacer widths. Your welcome to borrow and figure out what you need.
I’ll be working on my car next week Thurs and Fri, you’re welcome to come by the shop in Santa margarita and test it all there too...
PM me if any of that works...
Pat
garrettlee2
Oct 18 2019, 09:38 PM
What's the deal with the 4 lug hubs? I have been looking for that exact thing. Are you coming to G and R if so could you bring one?
jim_hoyland
Oct 19 2019, 05:06 AM
The 4 lug billet sets came and went years ago as well as the 5 lug sets, which I have on the car now. It was a great upgrade at the time; the SC vented rotors bolted up to the hubs and the wider 911M calipers could be installed. Very good for stopping !
jim_hoyland
Oct 19 2019, 05:08 AM
QUOTE(infraredcalvin @ Oct 18 2019, 08:33 PM)
Pat
Thanks for the offer, I’ll get back with you
