dgraves
Oct 19 2019, 04:23 PM
I'm replacing a stock 3 port FP with a 2 port on my '74 2.0 fuel injected 914. In order to avoid hose adapters, what FP do you recommend with what size inlet and outlet ports?
Many thanks.
ndfrigi
Oct 19 2019, 04:53 PM
Napa should have them. straight forward converting from 3 port to 2 port.
Before you replace your fuel pump, I suggest you do a fuel pressure check and match it after you replace it. Especially if currently your engine runs well.
