Have owned this car ('74 1.8) for many years, but never knew what this relay did. Is it only for starting purpose or does it do anything on how the car runs? Thanks for the replies. EdClick to view attachment
JeffBowlsby
Oct 27 2019, 06:21 PM
That's your 'dual relay'. Only found on L-Jet cars like your 74 1.8L. Its part of your fuel injection system. That thick red with black casing cable going to it supplies direct battery power to your FI system.
ClayPerrine
Oct 28 2019, 06:50 AM
But the fact that I can only see one fuel line coming out of the engine shelf means you have carbs. So you don't really need that relay, unless someone wired it up to run the fuel pump.
EJP914
Oct 28 2019, 02:27 PM
Thanks for the info. FI is long gone. Will check if wired to fuel pump, but I don't think so.
rgalla9146
Oct 28 2019, 04:19 PM
QUOTE(ClayPerrine @ Oct 28 2019, 08:50 AM)
Goodness gracious ! Clay you and Jeff are awsome. Unbelievable depth of knowledge.
brcacti
Oct 28 2019, 05:26 PM
Thanks Clay and Jeff, I (brcacti) ALSO was wondering what that relay was for, I do have FI so its important for me.
