In what sense? It's got several components to it that probably have varying degrees of difficulty to repair, but sure, it can be repaired. Is the basic problem that it is sticking -- not opening or closing? You can try soaking it in PB Blaster (or something else) for a day or two. You can also carefully pry open the body of it to clean it from the inside. I did that once, and it was not too difficult.
