My task this weekend it to determine why my right turn signal circuit blows fuse 9. The 4-way blows 9 and 11. With the turn signal wire detached from the rear light assembly the fuse is fine and the brake lights and left turn signal work. So I am thinking there is a short in that circuit. I have had two light assemblies installed and the problem persists.
Can someone tell me how I might find the problem area? Does the forward circuit separate from the rear? Where? How? Is there a connection behind the fuse block that can be undone?
The right rear wire disconnected shows ground but I haven't haven't written down the impedance. If the right front bulb is in, it won't be isolated from ground. Right?
Before I start, I'll eliminate the chance that the green directional light in the tach isn't the problem. Also, I have a new flasher relay coming.
Aren't 50 year old cars fun? Thanks in advance for your thoughts.
