Crudbud
Nov 3 2019, 12:08 PM
So I Stripped the shifter coupler threads tightening the Allen Screw to the shift rod. I ordered the threaded Insert from Auto Atlanta and need advice installing it. There are no slots to thread it in. Do I just tap it and lock-tight it in? Thanks.
Mark Henry
Nov 3 2019, 12:24 PM
Is it a case saver, helicoil or a timesert?
Helicoil and timesert have special proprietary taps that you would have to buy.
Do you have a link to the AA insert?
bdstone914
Nov 3 2019, 12:39 PM
There is not much material to use a threaded insert.
IronHillRestorations
Nov 3 2019, 03:55 PM
By the time you purchase a Helicoil or Timesert kit, I suspect you could source a good used coupler from someone in this group
injunmort
Nov 3 2019, 05:23 PM
a brand new coupler is $40.00. easier than reinventing the wheel.
Crudbud
Nov 3 2019, 06:07 PM
It does look just like a Time Sert and I guess I am screwed because I don't have the special tools and yes it would be the same cost as a new one then. They didn't mention any installation info on the Web page The part # is RW663. I will just buy a new one thanks.
Montreal914
Nov 3 2019, 07:07 PM
QUOTE(Crudbud @ Nov 3 2019, 04:07 PM)
Contact the person who sold it to you...
Garland
Nov 3 2019, 08:04 PM
You can drill out the hole, insert nut, and bolt.
It will never fail again, but there’s no turning back.
bdstone914
Nov 3 2019, 08:42 PM
QUOTE(Garland @ Nov 3 2019, 08:04 PM)
You would need to drill thru the coupler and rod and can use a 6m bolt and nut. I have seen it done. Or buy a new coupler
