We completely redesigned the relays to be more dependable and last much longer that those that are currently on the market. Originally these were to be solid state. Two things changed that.
First, in actual testing (yes we really do that) we found the thermal gain unacceptable, and know that we couldn't in good conscious sell that product. Yes they worked, but we were not comfortable putting them on the market as they didn't test well.
Second, we came up with a better design that the engineering suggests will last at least 200,000 cycles.
We are in the process of determining the actual failure point. As you can see from the video
https://youtu.be/PfVR3P-eaFg This will be running in the shop until failure.
There was another company that shal remain nameless that released relays into the market that had very high failure rates. My brother actually bought some and found 2 of the 5 he bought were bad righ out of the box.
Thant and initially they were cheap, but you saw the price points start creeping up to the point that they are in the $40 range.
We couldn't sit by and watch the 914 (and 911) community get screwed over buy poorly built over priced parts.That's why we made these.
So 1st off we are offering a 1 yr warranty We may even extend this as we continue to test, but for now it's an industry leading warranty.
We have expended a lot of resources to get these right. I will note that they are slightly larger than the OEM ones. This was necessary as part of the improved design.
We did check the fitment and the clearance on the relay board and the headlight plastic covers is good.
Here's the deal-
Like always we are giving the World community the best possible pricing
]We are offering up a set of 5 for $60 Yes $12 each!
There will be a option to pick up an extra 2 are the same price if you should so choose.
If you want individuals $15 each (Less than 5)
This will be for a limited quantity we are only going to offer 100 "sets" at the GB price as it's below cost.
After these are gone they will be $15 til the end of the month. The regular price will be $28
Our testing so far is in excess of 43,000 cycles. I know we were at 42k when I left Friday morning.
Ask Cary about being stuck on the side of the road when his new fuel pump relay (not ours), left him stranded on the side of the road.
@cary So who's in?
