QUOTE(brcacti @ Nov 9 2019, 07:58 PM)
QUOTE(ClayPerrine @ Nov 9 2019, 06:01 AM)
From the picture, I can tell you have an L-Jet car. None of the relays or fuses on that fuse panel will cause an intermittent no start.
The most common cause of intermittent no start on a 914-4 is the ignition switch. The switch is a VW part and the majority of the replacement switches are aftermarket low quality switches.
Here's a way to confirm it. Make up a light socket, with a spade connector on one wire and a loop connector on the other. Hook the loop to the ground point just in front of the relay board. Hook the space connector to the rear connector on the 4 pin plug next to the yellow wire on the relay board. When you turn the key to start the car, the light will light up. See if the light comes on when you are having the problem.
I will bet it doesn't light up when you have the issue.
The second most common issue is the seatbelt interlock relay under the passenger seat. Remove the seat and take a look. There will be a big yellow wire and a big yellow/red stripe wire. Disconnect them the relay socket and splice them together. I recommend doing this even if its not the problem, because it will be the problem in the future if you don't do it now.
Clay
Hello Clay what is an L jet car fuel ingection?
I have not been able to find the middle part for the two yellow wires to plug into under the passenger seat do you know what the part is called and/or where I can get it? On the ignition switch, I just ordered one from auto atlanta, do you think that one will be high enough quality? I have another question, the yellow wire I cleaned the connection of in the fuse panel behind the drivers seat I think that is very important, maybe a hot wire part of the add on starter relay ????, It has been starting every time since I cleaned that and the others in that box.
Seems like I read in another one of your posts that you already connected the two large gauge yellow wires with a wire nut??? If that's the case, then you have already separated them from their original connectors. If that's true, you should probably just use an automotive grade heat shrink butt splice and splice the two wires together.
If you have since tried to reattach the old connectors, that might be a point of failure, depending upon your wiring skills.
If you decide to go the butt splice route and are unsure of the wire gauge size, you can buy an assorted set at your local FLAPS for about $15. In the same aisle, you can buy heat shrink if you want to go that route, in which case you'll need a heat gun.
Just my 2 cents...
https://www.youtube.com/watch?v=8-cV7sY-s80
