QUOTE(dakotaewing @ Nov 11 2019, 10:55 PM)
Looking for pics and examples of in tank fuel pump set ups from those that have them.
My application is a an LS V8, but I'm looking for solutions others have used regardless of their power plant.
A pump outside the tank is likely problematic for my application -
Thanks!
I've never heard of it done in a 914 you likely would have weld in the mount on the tank plus plumbing...
You can mount an stock or aftermarket inline pump in the front trunk or back at the engine. If the reason is it's part of the LS computer I'm sure there's a work around. Usually if the pump has a pre-run event that's in the ECU and/or it has a stand alone relay with a timer, not in the pump.
My efi system has a relay that likely has a 555 timer chip for a 4 second pre-run.
