I cleaned paint and other crud to expose the serial number on the right front inner fender, but somebody removed it with a grinder. Is this standard procedure? All I can say is the the donor car was originally non-metallic green.
Looks like it was welded and ground down. I've seen a few cars where Body shops have done this when the put a complete clip on a car. Usually they will restamp the original vin though.
Cairo94507
Nov 18 2019, 08:40 AM
Sorry, but I have only ever seen that associated with stolen cars or car parts. I hope you can pull an image off the back side to see the VIN. That is frustrating.
914Sixer
Nov 18 2019, 08:52 AM
Could be as simple as it never got stamped, if nothing shows up on the bottom side.
Nov 18 2019, 01:23 PM
QUOTE(914Sixer @ Nov 18 2019, 06:52 AM)
Not stamped? As in, not stamped from the factory or not stamped as in a unstamped factory original replacement panel?
Also, why would they have to take the grinder to the top if it was never stamped?
