I can't seem to settle on what I should do here. I have a good 1.8 engine, that I probably could have just attempted to get running, but it was so greasy, I figured that it did not have too much maintenance done on it over the years.... I found a bearing had moved a bit and the dowel pin gouged it. But that is all I found. Measured the bearing saddles and they are all round and even front to back.
So I figured I would crack it open and give it new life with a stock rebuild. Just a daily driver, reliable engine with torque for the bus.
I want to put it in my 72 Bus. I figured I would go with new dual carbs and a new carb cam. Considering a mega squirt option tho. So that would be a different cam. On my 914 I got the cam package from Raby years ago, so I figured Type4store for the full cam package with all the goodies.
Again, I was thinking of 96mm P/C, but also figured I would save alittle $ and just re-install the 93mm stock P/C. But the 1911 option is still on the table.
The Heads are what really have me thinking. I would like to find a local shop that might be able to check them over, but I don't think there are VW experts around here now-adays. Should I try to do some checking myself? I am cleaning them up to look for obvious cracks. What else can I do myself?
I know the Type4store has great ones, just can't make myself pull the trigger. Even heard bad stories about AMC stock (non-type4 store ones) being not so good.
Asked similar questions on TheSamba but really did not get much advice.
You guys have any thoughts?
