QUOTE(drifter914 @ Nov 19 2019, 11:13 AM)
I would happily post a photo of the serial #... if there was one ! Looked all over, nothing except Bosch, the rebuilders sticker and the numbers 7-8-10-15 on the black plastic plug housing, which probably denote wire positions in the plug.
I did test this on my '74 914 2.0 before it was sold & worked perfectly, so I am willing to guarantee it works on your 2.0 liter. Money back if it doesn't. Since there is no serial # and it is a rebuild, I cannot verify the specifications. Perhaps it can be tested & calibrated. Not my concern. New ones are rarely available & are now running in the $700. range, if you can find one.
For $275., with a money back guarantee, I think it's worth a try...
Terry
FIC should have recorded the VW/Porsche/Bosch p/n - or if it was an aftermarket or other-maker item - on their receipt, & which MY & engines it works with. If not, you can probably contact them on their website with their FIC rebuilt p/n on their sticker to get that info.
While it worked on your 74 2L, it may not work well on a other MYs & engines, & that may lead one to believe that it's an -043 p/n or aftermarket/replacement version of same.
Cheers!
Tom
