Sold.....Thank you for all your interest. If for some reason the sell falls through the next in line will have an opportunity to purchase it........
1972 Porsche 914 ROLLER, less the 2056cc engine and transmission and exhaust system, which I just sold. The Rennshift Shifter has been removed and has the stock shifter. I was planning on either upgrading to a Porsche 3.0 or 3.2 or even looking at some Subaru engines but those plans have changed due to another Porsche 914 I ran across with a Raby 2270 engine in it which I’m in the process of buying. So I have decided to sell this 72-914 with a clean Oregon Title.
Very sold with no major rust. I've included a photo of the hell hole, this area floor was pitted but not rotted. After cleaning I found two small pinholes, these were drilled out to 3/8" for rubber plugs. I placed an endoscope down into the long below and there was no rust in this area that I could find. I've also included photos of suspension mount and jack point all in excellent condition. The battery tray and stand are in nice condition. I also looked at the floor of the longs from the inside of the cabin and found no rust in the back of the long where it turns up and doglegs over the rear wheel (same on both sides). I also looked at the front of the inside of the longs behind the front wheels only light surface rust on both of these front areas. No rust in any of the wheel wells, the doors are solid with no rust or rot on the doors or bottoms. The floors are solid with no rot. The rear trunk is nice (see photo) front trunk has been patched. This car originally had AC that at some point was remove so that explains the front trunk floor repair. There is evidence that this car had damage to the nose, the front trunk panel is a bit wavy (see photo) but no damage to the headlight boxes that I could see.
Paint is diy new in the past year and is not show quality but presentable for a driver, this car was originally silver from the factory.
Suspension: Early 911 Boge struts with Koni adjustable inserts and front sway bar. This set up includes vented rotors and M brake calipers with stainless steel soft lines. The rear is Koni adjustable shocks with stock rear springs, no rear sway bar. All the suspension and steering is tight and the car tracks very straight at speed. Real Fuchs 16 x 6 wheels with nearly new Firestone Indy 195/55 tires all around. The wheels are driver quality with some curb scratches at the rim but are not bent and run true.
The interior is clean and serviceable with new carpet. I have an oil temp, voltmeter and oil pressure gauge. The speedometer is accurate and was check with a GPS so 60 on the GPS shows exactly 60 on the speedo. A Momo Race Line steering wheel is installed, the horn works correctly. Sunvisors are in OK usable condition. The car came to me without OEM door pulls / armrests with the doors having accessory door pulls installed.
All the light work with the exception of the backup lights, the backup light switch on the trans is not wired. There is no emergency brake warning light switch at the emergency brake, the hand brake works great. The fog lights are in good condition and have been wired so they can work independently of the main light switch, headlights are H4 There is no back pad installed around the seats, interior light switches are not present at the doors. The turn signals and 4-way flashers work correctly but the turn signal stalk does not auto return to off you have to manually move it back.
The doors are from a later car with the scissors-type window lifts with impact bars inside the doors. The Ignition keys do not unlock the side doors or the trunk, they will need to be rekeyed. The windows work well, all the glass is good, the front windshield has a few small chips but is very serviceable, I'm sure it has been replaced but I don't know when.
The top is in good condition and does not leak or squeak thanks to some extra felt strategically placed. The Sails have just been recently installed along with the top sail across the roll bar.
VIN # 4722920749
Asking price $5,000.00
