@UROpartsman' date='Nov 22 2019, 06:10 PM' post='2764307']
[quote name='Mikey914' post='2764304' date='Nov 22 2019, 04:02 PM']
I'd be interested to hear how ours compare.[/quote]
Probably pretty similar, they almost look as if the molds were created from our bushings but with a part number added.
@Mikey914' post='2764304' date='Nov 22 2019, 04:02 PM']
I'd be interested to hear how ours compare. What I'm hearing here is they have multiple versions, and the vendors out there have to sell through what they have before they get the "good" ones.
Why not just recall them, as they are a known issue?[/quote]
There is no "known issue", we sell thousands of the OEM-durometer bushings annually and certainly won't be discontinuing them.
But most aftermarket bushings are "performance" bushings that are higher durometer than OEM, so folks have come to expect that degree of firmness. That's why we developed our HD version; so we can provide standard bushings for those who desire the OEM durometer feel, and HD bushings for those who want a performance feel without the potential squeaking of poly. They're two different part numbers.
We offer the HD bushings to existing standard-bushing users as a courtesy upgrade, if they want them. It's just to make sure they're happy, since the HD option probably wasn't available when they purchased the bushings.
[/quote]
I have used both Uro, 914 RUBBER and Elephant racing bushings. I will not use Uro ever again. I had used at least five sets Uro and they were easy to install due to the soft rubber.
I used Elephant racing tools to install.
I stopped using Uro because they were so soft they did not pull on evenly. Several gouged on the rear install. I had an extra set and found the next set was noticeably harder and different in appearance.
It was the same part number on the box
I threw them away and moved on.
There is no good reason to make a standard and HD version. Make it the same as OE.
When I contacted Uro about the installation problem, on this forum, the reply is that they would help find a qualified person to help me install them.
