Stock front torsion bar is 17.9 on a four and 18.8 on a six.
Stock rear springs were around 50 lbs and about 60lbs on a six.
It's easy to get to harsh, especially on the front. A mid 80's 911 Carrera only has 19mm front torsion bars and it's a 2700 lb car.
The formula for calculating spring rate is: k=d^4G where k=spring rate, d=diameter, G=modulus of elasticity (constant for steel)so ignoring the constant:
% increase in stiffness = ( (d2^4)- (d1^4) ) / (d1^4) * 100
where d2 is new diameter and d1 is original diameter
Stock Front = 18.8 increase to 21 mm = 55.7 % increase in spring rate.
Going from 17.9 to 21mm = 87.5% increase in spring rate
