My parking brake light will not come on. Following the posts here I have checked the E brake switch and it's working, checked the bulb and it's working and the continuity of the wire from the switch to the bulb is good. I tried to check the diode with my volt/ohm meter not really sure how and what to expect on ohm's and I have nothing. I bypassed the diode and the Brake Light Flashes when the E Brake is on. So is the diode bad? What do I replace it with? Or can I eliminate it, not sure what it does. Is the E Brake suppose to flash on a 73?
Thanks,
Rick 73 2.0
