Allan
Jul 1 2005, 08:54 PM
I am in the process of changing my oil and adjusting the valves and when I pulled out the strainer I found little pieces of metal shavings. I never saw these the first time I changed the oil after cam break in. Motor has about 500 miles on it.
grasshopper
Jul 1 2005, 09:13 PM
time to rebuild...or close. thats coming from the inside of the engine...
redshift
Jul 1 2005, 09:16 PM
dood.... lessee pics..
M
Allan
QUOTE (grasshopper @ Jul 1 2005, 08:13 PM) |
time to rebuild...or close. thats coming from the inside of the engine... |
Dude, this is a brand new motor. The only thing original are the cases.
Allan
Jul 1 2005, 09:18 PM
QUOTE (redshift @ Jul 1 2005, 08:16 PM) |
M |
I got no pics. My camera sucks at taking pictures of really small things.
That's why you never see any neked pics of me in the sand box.
rhodyguy
Jul 1 2005, 09:33 PM
damn!!! that stinks. any chance they are left over machining particles or are they chunky?
k
Allan
Jul 1 2005, 09:43 PM
QUOTE (rhodyguy @ Jul 1 2005, 08:33 PM) |
k |
No they are not chunks. Really thin, fine pieces. I hope it's just part of the breaking in process as things mate internally.
I'll probably just button it back up and re-check it after a hundred miles or so.
Tom Perso
Jul 1 2005, 09:45 PM
How does your filter look? Tear it apart and see what you find.
Check your valves again. See if they're loose.
Report back on your findings. Nothing to panic about, yet. Break-in always has some sort of nastyness in it.
Tom
brp914
Jul 1 2005, 10:02 PM
not unusual - motor on.... Worry time is: bad sounds, low oil pressure, white exhaust smoke, low compression
Joe Bob
Jul 1 2005, 10:07 PM
It's Jimmy Hoffa....look in the filter....change the oil and beat on it like a red headed step child.....then do a sixer conversion....
Allan
Jul 1 2005, 10:23 PM
QUOTE (Tom Perso @ Jul 1 2005, 08:45 PM) |
How does your filter look? Tear it apart and see what you find. |
I will follow your recomendation!! I wanna see what the hell is in it.
Bleyseng
Jul 1 2005, 11:44 PM
Where did you get the cam and lifters?????
Tom Perso
Jul 2 2005, 07:03 AM
QUOTE (Bleyseng @ Jul 2 2005, 12:44 AM) |
Where did you get the cam and lifters????? |
Good question - even though when they are matched - you can still have them go flat.
That's why I'll never build another Hi-Po Type 4 again. If it's not stock, it'll be a 6-er...
My 2270 has been a bundle of fun to drive, but a
to maintain.
Tom
SLITS
Jul 2 2005, 08:01 AM
Allan.........
1.) cut the filter (if you still have it) as described and check it for metal.
2.) button the sucker up and run it for a couple of hundred miles...check to see if the valves are seriously out of spec, check the strainer again and cut the filter again.
3.) Take all your clothes off, dance around the car while sucking on any good German Ale, sprinkling rust on the body to the sounds of "I Can't Drive 55" and send the video to A-aron Admin. DO NOT POST THE VIDEO.
Everything will be fine.................
ClayPerrine
Jul 2 2005, 08:11 AM
QUOTE (SLITS @ Jul 2 2005, 08:01 AM) |
Everything will be fine................. |
DOOD!!!!
Never sprinkle rust on a 914. Rust is Tinworm shit, and they live in it. If you sprinkle rust on a 914, you are infecting it with Tinworms. Left untreated, Tinworms will eat a 914!!!
SLITS
Jul 2 2005, 08:17 AM
QUOTE (ClayPerrine @ Jul 2 2005, 07:11 AM) |
QUOTE (SLITS @ Jul 2 2005, 08:01 AM) | 3.) Take all your clothes off, dance around the car while sucking on any good German Ale, sprinkling rust on the body to the sounds of "I Can't Drive 55" and send the video to A-aron Admin. DO NOT POST THE VIDEO.
DOOD!!!!
Never sprinkle rust on a 914. Rust is Tinworm shit, and they live in it. If you sprinkle rust on a 914, you are infecting it with Tinworms. Left untreated, Tinworms will eat a 914!!! |
Allan
Jul 2 2005, 10:23 AM
QUOTE (Bleyseng @ Jul 1 2005, 10:44 PM) |
Elgin......
Joe Bob
Jul 2 2005, 10:29 AM
QUOTE (Tom Perso @ Jul 2 2005, 05:03 AM) |
QUOTE (Bleyseng @ Jul 2 2005, 12:44 AM) | Where did you get the cam and lifters????? |
My 2270 has been a bundle of fun to drive, but a to maintain.
Tom |
Yup....much as liked bad boy fours....I decided to go sixers because I hate re-doing stuff....sixers stay together and in the long run are cheaper....
Type 4 Unleashed
Jul 2 2005, 10:40 AM
QUOTE (ClayPerrine @ Jul 2 2005, 06:11 AM) |
DOOD!!!!
Rust should not be sprinkled on, it should be forced injected into hard to reach places, then squirted with lots of salt water 5 times a day for 5 days, for it to really seat in.
redshift
Jul 2 2005, 11:56 AM
Ahhh rust seating... one of the most overlooked steps of break in.
M
Brando
Jul 2 2005, 12:20 PM
DOOD!!!!
LMFAO ... tinworms...
Joe Ricard
Jul 2 2005, 01:32 PM
Just to make you feel better I had small metal particles in the mini when I did the oil change @ 2000 miles.
Manufacture says go to 10K to change oil.
I just can't make myself do that.
I replaced oil with red line and should be getting my freebie change next month 10K. unless you get major valve clearance issues I'd say you'll be OK. I do highly recommend a long drive of maybe 3000 miles @ 80 to 90 MPH only stop for gas. If it holds up you got a one.
Allan
Jul 3 2005, 03:04 PM
Update......
Pulled the valve covers (nothing fell out) and adjusted the valves (first time by the way under the car all by myself
). Nothing too far out of spec. The 3 and 4 cylinder valves seemed to be the ones that tightened up the most. Down to about .003 on intake and .005 on exhaust. Didn't notice anything weird. Buttoned it all back up, filled it up with oil, put in new plugs and headed out for a ride. No strange noises and runs excellent!!!!!!
dmenche914
Jul 3 2005, 05:29 PM
You running a German oil filter? better not be an orange FRAM, frams are so junky, they will dump crap into your engine. I have had two FRAMs fall apart in use. Make sure you have a Mahle, or Mann oil filter, check you oil again soon, see if there is less metal next time (yippie!!!) also have an oil pressure gage, it is very important, and can tell you is bearings or pump is failing.'
good luck, maybe just break in crap i hope.
Allan
Jul 3 2005, 05:32 PM
QUOTE (dmenche914 @ Jul 3 2005, 04:29 PM) |
You running a German oil filter? |
Yep, Mahle all the time. I'm going to tear the old one apart and see if anything is in it.
dmenche914
Jul 3 2005, 05:37 PM
Ah, a German Filter usingman is truley a wiseman. Let us know if the German filter had a failure, that would be a first for me to hear about. You have a pressure gage? If so, what kind of pressure you get when warmed up at a given rpm?
Allan
Jul 3 2005, 07:20 PM
QUOTE (dmenche914 @ Jul 3 2005, 04:37 PM) |
You have a pressure gage? |
No, but I want one......
dmenche914
Jul 4 2005, 01:05 AM
I'd budget for that pressure gage, It is really handy to have, good to let you know if you have low oil, helps you know if your oil is getting too hot (it will thin out, dropping pressure) now a temp gage will tell you oil temp, but it can't give you pressure. A pressure gage will tell you if the oil is getting too hot, so given the choice of one or the other, go for the pressure gage. Also useful to let you know if your hard cornering is moving the oil away from the pick up tube, yikes, sudden pressure loss, so time to slow down on them turns (the oil baffle plate used on later engines helps a lot with this)
Anyway, you'll want to monitor you expensive engien investment with an oil pressure gage. Easy to install, use an electric one, not a direct mechanical one, as the mechanical one has too slow a response time with the long tubing needed to reach the engine, and thus won't tell you if you momentarily lose pressure in a fast turn.
Get that gage, record what is normal for your new engine, and keep an eye on it. It will also help in selecting the correct wieght (viscosity) of oil to use.
good luck on your new motor!!!!
