EDIT: brackets sold, several sets of plates available.
This is a set of restored early solid steel brackets used in Early 1970-1972? cars.
The pivot brackets are one pieces cast steel. The later brackets were cast zinc a with a steel pivot shaft pin inserted.
Later ones are more prone to breaking.
These are correct for a 914-6.
New steel packing plates were laser cut and zinc plated.
New allen head screws and flat washers included. I do need to add lock washers for these which are not in the picture.
You will need new bushings which are carried by 914Rubber.
Bracket set with plates and hardware $80 shipped - one set available
Plate set with allen screws and washers $25 shipped - several sets available
