rcarson25
Dec 1 2019, 06:25 PM
I am building my 1970 right now and I apparently have 1 early front brake rotor backing plate/ dust shield. I have a late parts car and have both front rotor backing plates from that. These early and late look different, but are they interchangeable? I have an early brake setup from pmb on the way and I need to figure out if I need to search for another early backing plate or if I can clean up the late model ones and run with those. Thanks in advance.
914Sixer
Dec 1 2019, 06:40 PM
Early and late are do not interchange due of brake caliper offset. Any reason you did not use the late set up?
injunmort
Dec 1 2019, 06:52 PM
if it will bolt on without interference and originality is not a concern, I would try it. early and late struts differ in offsets, so calipers and rotors differ, I don't know if the dust shields would make a difference. no ruby, no problem. buts that's me.
rcarson25
Dec 1 2019, 07:04 PM
QUOTE(914Sixer @ Dec 1 2019, 06:40 PM)
Shoot, thought that might be the case. I went early becausethe car came with an early 5 lug setup..
