you can use it without changing anything.
However most now use pertronix, a lot less complicated, hides under the distributor cap, just need to watch the heat
If you have carbs that is another matter, especially BIG carbs
QUOTE(brcacti @ Dec 4 2019, 03:51 PM)
Hello, I bought this crane system and had a few question. It said for best results to buy a crane coil and change the spark plugs. How important are these extra steps to do? Also with electronic ignition does the spark plug gap change or stay the same?
