QUOTE(brcacti @ Dec 7 2019, 03:51 PM)
QUOTE(914Sixer @ Dec 7 2019, 04:15 PM)
Make sure you save the wedge and nut off the clutch cable. Rev limiter may still good. They are NLA. Might clean up.
Thanks for that tip, will save the wedge and nut and rotor and toss the two cables in the recycle. 914sixer did you get the 2 parts I sent you?
Yes, save the clutch cable hardware. On my 76 the clutch clevis (wedge) was originally a nylon plastic piece (what were they thinking, save a dollar?), which on my car lasted about 90,000 miles, before it failed and left me stranded, luckily near home. The replacement was a metal clevis.
The clutch cable and hardware should be considered to be a required spare, especially if you travel far from home. You won't find these parts at the local auto parts store.
