Full Version: Only slightly OT: spray carpet die can be really handy
Tdskip
I have to admit I was very skeptical before having actually tried this, but I have to say it’s exceeded my expectations.
This is the 1984 928 that sat badly stored outside in Tustin for 18 years before I rescued it. It only had 74,000 miles on it, so the materials were not worn out they were just a bit dirty and sun faded. After cleaning the carpet surfaces really well but gently and allowing it to dry I brushed it with a stiff nylon brush. After that I sprayed a very light coat of die and then immediately worked it in with the same brush.
I expect there may be disagreement on this but for my daily driver use this is perfectly acceptable. Well worth the $16 can and some elbow grease.
Tdskip
Tdskip
jim_hoyland
Amazing product, I used it on a badly discolored center deposit box. Looked like new smile.gif
RickS
I use it on my bald spot.
Tdskip
Ha!
Mikey914
In areas like the rear hatch carpet I have used on my 944. I tried on my floor carpets, the passenger held up well, but the drivers started showing wear again fairly quickly.
But for the price, yes worth it!
porschetub
QUOTE(Mikey914 @ Dec 9 2019, 09:41 PM) *
Clean and vac over and over it works fine,if you don't clean the carpet its a waste of time IMO.
aj88cab
I have used liquid Rit Fabric die, with good results. Used a pump spray bottle for in car carpet applications. Mixed about 4 parts water to 1 part dye (that stuff is concentrated!). I use a brush to work it in and/or massage it in with nitrile gloves in those hard to reach spots. Takes a day in the hot sun to dry completely, but for a cheap SOB like me, it beats a $20 rattle can. As noted, a clean carpet is key for good & lasting results.
I have also used it in a big plastic tub for recoloring original factory floor mats, if they are not all worn out.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
